Vecchio 20 luglio 12, 09:55   #41 (permalink)  Top
L'avatar di RAMIREZ76
Data registr.: 14-04-2008
l'emcotec supporta assorbimenti max di 10A ...
DPSI Micro DualBat 5.5V/5.9V JR - dual power supply | DPSI Micro Family | DPSI SYSTEMS
questo ..20
MAX BEC 2 - BEC regulators » MAX BEC 2 : JETI model s.r.o.
TJrc su Facebook
RAMIREZ76 non è collegato   Rispondi citando
Vecchio 20 luglio 12, 10:05   #42 (permalink)  Top
GiorgioTNT
Guest
Messaggi: n/a
25 amp di picco ...... l'emcotec
  • Power sources: 5, 6 or 7 cell NiCad / NiMH cells, 2 cell Lithium-Ion, LiPo, LiFePO4 batteries
  • Operating voltage range: 4.8V to 12V
  • Nominal input voltage: 6.0V to 8.4V
  • Output voltage: 5.9V or 7.2V per sliding switch selectable
  • Quiescent current (turned off): <1µA per battery
  • Quiescent current (turned on): Approx. 90mA in total (LED on)
  • Max. continuous current @ 5.9V (15 minutes for LiPo batteries): 4A
  • Max. peak current @ 5.9V (10 seconds for LiPo batteries): 10A
  • Max. peak current (20ms): 25A
  • Drop out losses @ 2A: 0.4V
  • Ripple 0,1A / 8A: Approx. 200mV
  • Max. power dissipation: 8W
  • Number of servos in system: Depending on application up to 10 servos. At high loads (and powerful digital servos) possibly only up to 7 servos usable.
  • CE test: According to 2004/108/EC
  • Environmental conditions: -10°C (14°F) to +50°C (122°F)
  • Permissible Temperature Range: -25°C (77°F) to +85°C (185°F) (Storage)
  • Protecting dynamo effect: Limiting of pulses to approx. 7.3V
  • Dimensions: 73.4 x 19.4 x 14.1mm (2.9 x 0.76 x 0.55in)
  • Screwing diameter for mounting: 2 x 3mm (0.12in) 66.2mm (2.6in) spacing
  • Diameter LED: 5mm (0.2in)
  • Weight: Approx. 28g (0.9oz)
  • Warranty: 24 month
Ultima modifica di GiorgioTNT : 20 luglio 12 alle ore 10:10
  Rispondi citando
Vecchio 20 luglio 12, 10:11   #43 (permalink)  Top
12 A costanti lo jeti
TJrc su Facebook
Vecchio 20 luglio 12, 10:13   #44 (permalink)  Top
GiorgioTNT
Guest
Messaggi: n/a
Originalmente inviato da RAMIREZ76 Visualizza messaggio
non mi piace lo Jeti....troppo ingombrante
  Rispondi citando
Vecchio 20 luglio 12, 10:18   #45 (permalink)  Top
Si ma é molto robusto (monocilindrico ringrazia) e un interruttore a "strappo" praticamente eterno (alla fine è un banale ponticello)
TJrc su Facebook
Vecchio 20 luglio 12, 10:25   #46 (permalink)  Top
GiorgioTNT
Guest
Messaggi: n/a
spiacente preferisco di gran lunga l'emcotec ... non lo cambiarei con nessun altro sistema !
piccolo, costruito benissimo, praticamente invisibile un bel led esterno e visibile che ti avvisa il low level delle lipo fail safe impostabile per non danneggiare le lipo se lo dimentichi acceso
  Rispondi citando
Vecchio 20 luglio 12, 10:29   #47 (permalink)  Top
GiorgioTNT
Guest
Messaggi: n/a
Nino...........non hai chances !!! ahahahahaha
  Rispondi citando
Vecchio 22 luglio 12, 22:32   #48 (permalink)  Top
L'avatar di gvnn71
Data registr.: 14-07-2009
Residenza: Asiago (Vi)
ecco lo jeti, prima avevo l'emcotec, preferisco questo, poi ognuno monta ciò che gli da più fiducia.
Sebart Su 29 2.2- DLE 111 - Vendo tutto
gvnn71 non è collegato   Rispondi citando
Vecchio 22 luglio 12, 22:49   #49 (permalink)  Top
Uguale al mio
TJrc su Facebook
Vecchio 23 luglio 12, 22:15   #50 (permalink)  Top
GiorgioTNT
Guest
Messaggi: n/a
Uguale al mio
confessa lo hai pagato per questa comparsata !!!
  Rispondi citando
centralina 678-016??? bayliss_12 Elimodellismo Motore Elettrico 0 02 ottobre 08 11:15
Centralina bybidue Elimodellismo Principianti 5 18 luglio 08 20:05
centralina bybidue Elimodellismo Principianti 2 12 luglio 08 18:26
Centralina gallina Aeromodellismo 7 21 marzo 07 00:33
4 IN 1 CENTRALINA DF4 kitaro Elimodellismo Principianti 4 19 settembre 05 15:40
Tutti gli orari sono GMT +2. Adesso sono le 07:57.
