Vecchio 15 giugno 12, 08:21   #1 (permalink)  Top
L'avatar di axel83aerei
Data registr.: 17-12-2010
Residenza: torino
Habu 32 Wemotec Midi Fan 80mm Carbon
CIAO a tutti nuovo esperimento per il mio Habu 32, girando avevo trovato la Jetfan 80mm che va' molto bene ma non mi soddisfava moltissimo, ma questa e' uno spettacolo, pesa pochissimo ho tolto altri 150g buoni dal mio habu per un totale di 2950g con una spinta di 2850g ottimo ventola efficentissima e consuma pure poco inoltre kit ventola e motore ad un super prezzo ecco le caratteristiche:
For 6s Lipo, 89 A, 28.5 N of thrust
This unit is a tuning drive for the HABU 32 or similar models and highest performance on 6s lipo. Since current can reach up to 100 A readily installed, we recommend 5.000 mAh cells 30 C or better and a good 120 A speed controller. Throttle management is recommended to reach a good flying time.
Midi Fan pro 80 is a shortened Version of our well known Midi Fan pro, trimmed down to 80 mm and fitted with a light carbon fibre shroud.
The shroudis compatible with the shroud of the 80 mm Eflite fan, which is being used in HABU 32 and similar models.
The fan unit comes completely mounted with a Tenshock EZ 22-30-9T motor.
The unit is assembled and checked at factory, precision balanced and harmonically tuned.
Set comprises:
1 x Midi 80 pro ducted fan unit
1 x Tenshock EZ 22-30-9
inner diameter: 80,0 mm
outer diameter: 83,6 mm
length of shroud: 66 mm
weight, complete: 292 grams
fan swept area: 37,68 qcm
rotor: 6-blades, Nylon (glass reinforced)
power input approx. 2.000 W
thrust: 28,5 N (approx. 2.85 kg)
rec. battery: 6s lipo, from 5.000 mAh 30C or better
rec. thrust tube dia.: 62 mm dieameter
Timing ESC: approx. 12°
PWM: 8-12 kHz
ecco il link. Midi Fan 80 ducted fan unit / Tenshock EZ 22-30-9T, 169,90 €
La potenza e' nulla senza il controllo
axel83aerei non è collegato   Rispondi citando
Vecchio 15 giugno 12, 09:37   #2 (permalink)  Top
L'avatar di mauryr
Data registr.: 10-02-2011
Residenza: Ghisalba
Interessante: una soluzione 6s piu' performante e leggera dell'originale per un prezzo simile...
Per avere quel peso tu lo lanci vero? Niente carrelli?
Ci posti un video? Vorrei vederlo volare
Ciao, grazie.
Ultima modifica di mauryr : 15 giugno 12 alle ore 09:43
mauryr non è collegato   Rispondi citando
Vecchio 15 giugno 12, 10:41   #3 (permalink)  Top
L'avatar di vittoriozuzio
Data registr.: 18-07-2008
Residenza: Firenze
hai visto questa? mi sembra un ottimo prodotto, e avresti un suono diverso dalle 5 pale, come di moda adesso.
Impeller - Modellflugzeuge, Modellbau, Jetfan - eJets - Eliminator
certo vuole un motore da 36.
Vittorio
Parkzone HABU - EFA 360 - -SAAB Jas 38 -Velocity-RC Boogie Hawk
vittoriozuzio non è collegato   Rispondi citando
Vecchio 15 giugno 12, 11:21   #4 (permalink)  Top
Residenza: torino
jet fan
Originalmente inviato da vittoriozuzio Visualizza messaggio
Vittorio
Si la conosco infatti ho scritto che l'avevo presa in considerazione ma purtroppo oltre al bel suon vai a cascare nuovamente in peso aggiuntivo con motore 36 maggiori consumi regolatore piu' grosso insomma per poi non guadagnare quasi niente percio' ho optato per l'efficienza piuttosto che il sound...ciao
Vecchio 15 giugno 12, 11:43   #5 (permalink)  Top
Residenza: torino
carrelli
Originalmente inviato da mauryr Visualizza messaggio
Ciao, grazie.
Ciao sono riuscito ad ottenere una configurazione cosi' leggera montando carrelli ad aria hobbyking quelli blu gambe ammortizzate epf, tutti microservi digi inrgran. in metallo e batterie 4500 35c 6s alla fine per un peso di 2,950/3kg.
Vecchio 15 giugno 12, 12:19   #6 (permalink)  Top
L'avatar di mauryr
Residenza: Ghisalba
Originalmente inviato da axel83aerei Visualizza messaggio
Ottimo, il mio sta sui 3,5kg ora come ora. Non che mi freghi piu' di tanto: in atterraggio lo trovo piu' divertente e cmq atterra bene, non mi dispiacerebbe un po' piu' di velocita' pero'...
Magari dovrei iniziare prendendo batterie decenti e levare un po' di prolunghe inutili (quando l'ho costruito non mi sono preoccupato piu' di tanto e ho lasciato alcuni cavi lunghi internamente, dovrei rifarli tutti senza prolunghe, ma non ne ho nessuna voglia ;)
Giusto x curiosita', che valvola usi per far funzionare i carrellini?
Vecchio 15 giugno 12, 17:38   #7 (permalink)  Top
L'avatar di iperquilibrio
Data registr.: 28-02-2010
Residenza: Rimini
Ti sei accertato che la spi ta della ventola sia effettivamente quella??
No perche' se devi perdere anche solo 3 etti rispetto a quanto dichiarato...
Fin'ora le configurazioni gia' con il motore montato hanno sempre dichiarato di piu'!
Lander in primis, anche se vanno bene... solo le vasa le dichiaravano a seconda del tipo di motore e di celle ed effettivamebte mi ci sono ritrovato come valori... Sulle altre sono diffidente, magari vedi se su qualche forum l' hanno gia' provata
iperquilibrio non è collegato   Rispondi citando
Vecchio 16 giugno 12, 00:05   #8 (permalink)  Top
Residenza: torino
Si effettivamente mi sono dedicato parecchio ad eliminare materiale inutile come cavi etc.. in eccesso come valvola uso una Airpower.
Vecchio 16 giugno 12, 00:10   #9 (permalink)  Top
Residenza: torino
Originalmente inviato da iperquilibrio Visualizza messaggio
Ciao allora come spinta misurata grezzamente cioe' modello a terra bilancia digitale con cavo montato al posteriore (non ho resistito nel montarla) misura circa 2980 al massimo con un assorbimento di 89/92 A di consumo ma la cosa bella che a poco piu' di meta' stik tira 2,1kg quasi come la ventola di seria Delta V32 ed ha un consumo di 48/50A percio' facendo due conti molto brevi volo con poco piu' di mezzo stik come con la ventola originale al massimo ma consumo decisamente meno e quando voglio il brivido via a tutto gas.
Vecchio 16 giugno 12, 09:53   #10 (permalink)  Top
Residenza: Firenze
buono!!! però provala nel modello, potrebbe cambiare qualcosa...
Vittorio
ventola Wemotec - Mini Fan 480 per il fragolino leo59 Aeromodellismo Ventole Intubate 11 12 giugno 08 22:51
WeMoTec Mini Fan 480 Odi Aeromodellismo Ventole Intubate 18 05 settembre 06 11:22
Wemotec Midi Fan 480 Odi Aeromodellismo Volo Elettrico 93 22 febbraio 06 15:05
Tutti gli orari sono GMT +2. Adesso sono le 14:13.
