24 ottobre 08, 20:52 | #1 (permalink) Top |
User | Ventola di ultima generazione
Salve.. volevo farvi vedere cosa ho scoperto per caso sul web: Schubeler Carbon Electric Ducted Fan Units - High performance Schubeler edf available now Schubeler Jets - EDF All ducted fans of the DS-XX-DIA HDT series come fully assembled, fine-balanced and quality-checked, you simply have to install your motor and the system is ready to fly. Schubeler DS-26-DIA HDT Carbon Electric Ducted Fan Units - High performance Schubeler edf available now 300 USD HDT = High Dynamic Thrust The 65mm fan for highest dynamic thrust The DS-26-DIA HDT is based on the DS-30-DIA HDT and is with 65mm diameter our smallest fan unit. Its aerodynamic characteristics are a perfect match for small and fast EDF jets. The rotor has only 3 blades which however have a big depth for an efficient airflow. Unlike other ducted fans of this diameter class its short rotor unit runs very smoothly and does not even overload a thin 3.17 mm shaft with undesirable resonance vibrations. Like his "big brothers" the DS-26-DIA HDT is also fully made of carbon fibre. All ducted fans of the DS-XX-DIA HDT series come fully assembled, fine-balanced and quality-checked, you simply have to install your motor and the system is ready to fly. Technical Data: Diameter: 65mm Fan swept area: 26cm² Weight incl. Secure Fan Fix frame: 30g Static thrust range: tbd Max. motor diameter: 29,3mm Speed range: 22.000 - 50.000U/min Power input: tbd Static efficiency: tbd More measurements for this ducted fan can be found at fan measurements. Schubeler DS-30-DIA HDT Carbon Electric Ducted Fan Units - High performance Schubeler edf available now HDT = High Dynamic Thrust The 69mm fan for highest dynamic thrust 300 USD Schubeler DS-44-DIA HDT Carbon Electric Ducted Fan Units - High performance Schubeler edf available now 365 USD HDT = High Dynamic Thrust The 85mm fan for highest dynamic thrust Like all Schubeler fans the DS-44-DIA HDT is "made in Paderborn" in all-carbon fibre design. You can rely on the combination of low weight and ultra-high strength! The limiting factor for maximum power input is the motor - not the ducted fan. Schubeler DS-51-DIA HDT Carbon Electric Ducted Fan Units - High performance Schubeler edf available now 365USD HDT = High Dynamic Thrust The 90mm fan for highest dynamic thrust Schubeler DS-75-DIA HDT Carbon Electric Ducted Fan Units - High performance Schubeler edf available now 440 USD HDT = High Dynamic Thrust The 110mm fan for highest dynamic thrust The DS-75-DIA HDT is based on the larger DS-94-DIA HDT and constructed in the same way with its outer diameter being reduced to 110mm. The smaller DS-75-DIA HDT can be used in models of the former 7.5cm³ ducted fan class. Schubeler DS-94-DIA HDT Carbon Electric Ducted Fan Units - High performance Schubeler edf available now 440USD HDT = High Dynamic Thrust The 120mm fan for highest dynamic thrust With a fan swept area of 94cm² and a diameter of 120mm the DS-94-DIA HDT is currently our biggest and most powerful ducted fan. This fan can efficiently convert power inputs of up to 5.7KW into a very high thrust impulse - thus being an ideal alternative for turbines of the 80N-class. Along with the design of its predecessor - the DS-94-DIA 3-ph - we developed the 8mm shaft system - by now an established and absolutely necessary size for handling the high motor powers in a 120mm fan unit. The optionally available Secure Fan Fix system now also provides the possibility to precisely and securely fix the ducted fan within the fuselage. Like all our ducted fans the DS-94-DIA HDT is also produced in CAD-CAM molds, hand-laminated and assembled in Paderborn.
__________________ FunCub Piper J3 semi-replica con Hacker A30-14L v2, MiniMag brushless 3s, Mini Titan e325, Parkzone Bf109 con hacker A30-16L, futaba 7c |
24 ottobre 08, 20:54 | #2 (permalink) Top |
User |
Queste cose sono solo per chi mastica l'inglese.. con un convertitore potreste convertirle in italiano... Vi ho voluto copiare le parti + importanti.... dicono che siano ECCEZZIONALI Qui c'è il sito shubeler-jets Schübeler - the future of electric jets
24 ottobre 08, 21:47 | #3 (permalink) Top |
User Data registr.: 04-02-2004
Le uso da parecchio..... eccezzionali è dire poco.......le HDT poi sono magiche.....hanno un 'efficenza altissima, che ti fa risparmiare un mucchio di corrente! Io uso solo DS oppure TF di Aeronaut. PS: Non è per smentirti....ma non sono proprio di ultima generazione.... sarà già 7-8 anni che ci sono sul mercato..... Ciò non toglie che sono per me le numero 1. Ciao
__________________ Sito del mio gruppo :www.gvfalchetto.it |
24 ottobre 08, 21:52 | #4 (permalink) Top | |
User Data registr.: 04-02-2007 Residenza: Sesto Fiorentino Firenze
24 ottobre 08, 23:28 | #7 (permalink) Top |
User Data registr.: 30-11-2005 Residenza: reggio emilia
no problem : 1 Newton = 0,102 kgf = 0,0001 t = 0,2248 lbf = 3,597 ozf e se puo' farvi comodo ecco una bella tabella con tutte le unita' di misura Unità di misura - conversioni ciao ciao |
25 ottobre 08, 01:49 | #8 (permalink) Top |
User Data registr.: 02-10-2006 Residenza: Udine
dividi per 9.81 (io divido per dieci che si fa prima un po come un euro = 2000 lire)
__________________ Uno dentro... Sei fuori... [...] Fortunato colui che può con ala vigorosa slanciarsi verso campi sereni e luminosi abbandonando i vasti affanni e i dolori peso gravante sopra la nebbiosa vita. [...] ( C. Baudelaire ) |
26 ottobre 08, 09:28 | #10 (permalink) Top |
Moderatore Data registr.: 25-07-2005 Residenza: Livorno
| e che volevi..... materiali pregiati, costruzione curatissima, prestazioni migliori..... 'ste cose si pagano bello....
__________________ PERDONA SEMPRE I TUOI NEMICI MA NON DIMENTICARTI MAI CHI SONO (J.F.K.) ....se votare facesse qualche differenza, non ce lo lascerebbero fare..... (M.Twain) |
motore dl50 3a generazione con carburatore walbro... | danixt75 | Aeromodellismo Volo a Scoppio | 16 | 19 agosto 08 11:01 |
Ultima spiaggia | gelototale | Automodellismo Mot. Scoppio On-Road | 8 | 21 marzo 08 01:07 |
DL 50 2°generazione | thom33it | Aeromodellismo Volo 3D | 2 | 02 novembre 07 23:57 |
l' ultima creatura............ | 41fabio73 | Aeromodellismo Alianti | 37 | 25 gennaio 06 09:58 |
lipo di seconda generazione.. | iacopo | Aeromodellismo Volo Elettrico | 7 | 26 agosto 05 09:53 |
