31 maggio 13, 12:11 | #42 (permalink) Top |
User Data registr.: 21-07-2006 Residenza: Ferrara - Molinella
The super high cadence ECU processor coupled to the high bandwidth Xbus digital serial bus enables to pilot brushless digital starter motor and fuel pump pole by pole. This means the following for the starter motor: A much higher starting torque giving a more position clutch engagement and less clutch and o'ring wear. A punchier starting thanks to the motor torque. A more positive starter motor disengagement. A more clever piloting of the starting cycle. For the pump, the following benefits are achieved: A very precise control of the fuel metering since the ECU can pilot the pump pole by pole and control resolution is 1 RPM! Fuel metering s now to the milliliter! A very fast change in the fuel flow output. The fuel flow is monitored 100 times per minute and precisely altered as soon as change in the combustion cycle is detected In practice this means a much more stable combustion cycle. This is especially important for operating the engine in extreme outside air conditions. Very cold or very warm and humid, as well as in high density altitude conditions are not a problem for the new engine. Also, Idle regime is even more stable than before. The brushless pump itself is a professional grade type. It features two ball bearings, automotive seals and reinforced pump geaR |
31 maggio 13, 13:48 | #43 (permalink) Top | |
User Data registr.: 10-09-2011 Residenza: AUCH ,Francia
Ne avro una fine Giugno. Ciao Jean-Pierre
__________________ F-104 ,Merlin 90 K Rafale AD ,M 200 XBL -Mirage 2000 AD ,M 140 XBL SU 35 AD ,2 X M 100 XBL | |
03 giugno 13, 14:44 | #44 (permalink) Top | |
Alluminio a basso costo................... | maddriver967 | Aeromodellismo Ventole Intubate | 43 | 14 febbraio 13 23:24 |
Simulatore o modello a basso costo elettrico per iniziare? | rextex | Aeromodellismo Principianti | 10 | 06 aprile 12 22:54 |
lipo a basso costo? | PredatorX10 | Automodellismo Mot. Elettrico On-Road | 7 | 20 gennaio 09 15:23 |
LI-PO basso costo | FLUO | Elimodellismo Motore Elettrico | 26 | 07 aprile 05 15:31 |
