05 settembre 10, 00:36 | #102 (permalink) Top |
User Data registr.: 28-11-2009 Residenza: Palermo
Motivo della spenta. Messaggio di errore sul displey del terminale del FADEC: SpeedLow T=424°C RPM 19.000 Pw 120 I giri della turba sono scesi sotto il valore minimo impostato sul FADEC (20.000 RPM) e questo ha interrotto la mandata di kero fermando la pompa. Di sotto un' estratto dei dati estrapolati dal FADEC: "Cycle","Page","Aux","Temp","RPM","Throttle","Pump " 49,113,0,616,110000,878,183 49,113,0,612,105000,828,156 49,113,0,604,103000,824,156 49,113,0,600,103000,722,144 49,113,0,588,96000,695,136 49,113,0,576,95000,695,132 49,114,0,576,94000,695,132 49,114,0,572,94000,695,132 49,114,0,568,94000,695,132 49,114,0,568,93000,667,132 49,114,0,568,93000,671,132 49,114,0,564,93000,628,121 49,114,0,564,87000,589,109 49,114,0,556,83000,589,109 49,114,0,552,82000,589,109 49,114,0,552,83000,589,109 49,114,0,556,82000,589,109 49,114,0,556,81000,589,109 49,114,0,560,80000,589,109 49,114,0,560,81000,593,109 49,114,0,564,82000,593,109 49,114,0,560,81000,593,109 49,114,0,556,81000,593,109 49,114,0,560,81000,593,109 49,114,0,556,80000,593,109 49,114,0,556,80000,593,109 49,114,0,556,80000,593,109 49,114,0,552,79000,593,109 49,114,0,556,79000,593,109 49,114,0,556,79000,593,109 49,114,0,560,79000,593,109 49,114,0,560,80000,589,109 49,114,0,556,79000,613,105 49,114,0,560,78000,644,117 49,114,0,564,85000,644,121 49,114,0,576,84000,437,93 49,114,0,552,68000,414,85 49,114,0,536,63000,316,85 49,114,0,528,61000,300,82 49,114,0,532,60000,308,82 49,114,0,536,59000,316,82 49,114,0,544,59000,367,82 49,114,0,548,59000,378,82 49,114,0,556,59000,378,82 49,114,0,556,58000,374,82 49,114,0,556,57000,378,82 49,114,0,556,58000,374,82 49,114,0,556,57000,374,82 49,114,0,556,57000,382,82 49,114,0,552,55000,374,82 49,114,0,552,55000,371,82 49,114,0,552,55000,351,82 49,114,0,552,55000,355,82 49,114,0,556,56000,316,82 49,115,0,556,56000,300,82 49,115,0,556,56000,312,82 49,115,0,556,56000,312,82 49,115,0,556,55000,312,82 49,115,0,556,55000,312,82 49,115,0,552,55000,312,78 49,115,0,556,55000,316,78 49,115,0,552,55000,316,78 49,115,0,552,55000,316,78 49,115,0,552,55000,316,78 49,115,0,552,54000,316,78 49,115,0,548,54000,316,78 49,115,0,552,54000,316,78 49,115,0,548,53000,316,78 49,115,0,544,52000,320,78 49,115,0,544,51000,316,78 49,115,0,544,51000,316,78 49,115,0,548,50000,335,78 49,115,0,548,50000,355,78 49,115,0,556,50000,355,78 49,115,0,556,50000,355,82 49,115,0,564,51000,355,82 49,115,0,568,53000,347,78 49,115,0,568,52000,351,78 49,115,0,552,48000,355,85 49,115,0,540,38000,367,97 49,115,0,496,27000,460,105 RPM di sotto dei 32.000 impostati per l'IDLE e il FADEC da più tensione alla pompa per aumentare i giri 49,115,0,424,19000,437,0 RPM al di sotto del valore minimo impostato sul FADEC, pompa del kero in OFF e SPENTA TURBINA 49,115,0,392,16000,437,0 49,115,0,360,13000,445,0 49,115,0,340,11000,445,0 49,115,0,328,10000,445,0 49,115,0,316,9000,445,0 49,115,0,308,8000,460,0 49,115,0,296,7000,464,0 49,115,0,292,6000,460,0 49,115,0,284,6000,460,0 49,115,0,280,5000,484,0 49,115,0,276,5000,484,0 49,115,0,276,5000,484,0 49,115,0,272,4000,492,0 49,115,0,268,4000,492,0 49,115,0,272,4000,503,0 49,115,0,268,4000,499,0 49,115,0,268,4000,554,0 49,115,0,268,3000,546,0 49,115,0,264,3000,542,0 49,115,0,264,3000,589,0 49,116,0,264,3000,582,0 49,116,0,264,3000,542,0 49,116,0,264,3000,542,0 49,116,0,260,3000,542,0 49,116,0,252,3000,546,0 49,116,0,248,2000,542,0 49,116,0,244,2000,468,0 49,116,0,236,2000,398,0 49,116,0,236,2000,394,0 49,116,0,228,2000,300,0 49,116,0,232,2000,414,0 49,116,0,228,2000,398,191 Non c'è stata fumata e quindi probabilmente c'è stata una interruzione della mandata di carburante; bisogna capirne la causa, bolla d'aria, ostruzione o... E dire che a terra abbiamo fatto parecchie prove senza riscontrare alcun problema. E va be, rimetteremo la turba al banco con tutto il sistema di alimentazione montato sul modello e vedremo... Saluti
__________________ Salvatore Ciambra - Palermo (Italy) __________FAI 11105 |
05 settembre 10, 11:05 | #104 (permalink) Top | |
sapessi quanto ti invidio l'essere andato a Orvieto... C'è gia uno Sheliak in costruzione e quindi la turba andrà li, comunque forse, se la fusoliera dello SkyJet non ha subito danni strutturali, vedremo per un nuovo paia di ali e pianetti, questa volta in fibra però. Saluti
__________________ Salvatore Ciambra - Palermo (Italy) __________FAI 11105 | |
06 settembre 10, 04:05 | #105 (permalink) Top |
User Data registr.: 14-04-2008
i modelli erano tutti SUPER!!!! veramente l'imbarazzo.. (quest'anno si sono superati!!!!) ecco alcune fotine [url=http://www.voloclubfenice.com/modules.php?name=Forums&file=viewtopic&p=5246#5246]5° JJM 2010 - come promesso, ecco alcune foto del 5° Jonathan Jet Meeting 2010 ad Orvieto [URL=http://w[/url] Ultima modifica di RAMIREZ76 : 06 settembre 10 alle ore 04:10 |
06 settembre 10, 16:21 | #106 (permalink) Top | |
User Data registr.: 24-03-2008 Residenza: Trapani
Ti sei allustrato gli occhi! Mi sa tanto che a presto ci sarà un nuovo turbinaro in Sicilia. | |
06 settembre 10, 16:57 | #108 (permalink) Top | |
Come ti comprendo! Ascolta possiamo fare un patto d' onore da veri Siculi. Giochiamo al superenalotto il primo che fa una vincita superiore a 100000,00. Compra due modelli. Che ne pensi? | |
06 settembre 10, 17:18 | #109 (permalink) Top | |
se ti va bene un BAE HAWK RED ARROWS (mi sono fissato con questo modello di Stefan Schönweger) da 2.60 AA con turbina da 18kg e "dissuatori" montati.. considera l'affare fatto scusate l' OT | |
Stage di pilotaggio jet a Palermo... | S_Ciambra | Aeromodellismo Ventole Intubate | 10 | 06 luglio 10 19:24 |
1° - Stage F3a - Macroarea Sud - | gereco | Aeromodellismo Categorie | 1 | 28 marzo 10 23:57 |
stage, corsi e master.... | LV-GDG | Aeromodellismo Alianti | 14 | 27 novembre 09 22:02 |
Difficoltà nel pilotaggio di Jet ed aerei particolarmente VELOCI... | AlexxZeta | Aeromodellismo Ventole Intubate | 34 | 16 agosto 08 11:16 |
