![]() | #312 (permalink) Top | |
User Data registr.: 14-06-2006
"2. Fuel, tank, piping ●Since gasoline is dangerous material, be careful of its storage, use, and transport enough. ●Unleaded high-octane gasoline is not required for SAITO engine. ●The fuel is mixture of commercial regular gasoline and reliable oil for 2-stroke engines. ●[Example of oil recommendation] ・ Klotz KL-200 Original Techniplate ・ Morgans Cool Power 'Blue' Synthetic Lubricant etc. ●Lubrication for piston, connecting rod, bearing or cam gear is a blow-by lubrication in which the oil in the fuel goes into the crankcase from the clearance between the cylinder and piston. Therefore the engine life is affected by the property of the fuel oil. Please use the oil of reliable quality. ●Please be sure to use the mixture gasoline : oil =15~20 : 1 by volume ratio. (Ex. 1000ml of gasoline should be mixed with more than 50ml of oil )." | |
![]() | #313 (permalink) Top | |
User | Citazione:
un esempio evitare lub. destinati a go kart o cmq. a motori 2t che girano forte , meglio i lub. destinati a motori che lavorano a bassi giri es ...motori da cross , quad , fuoristrada in generale ....ovviamente con specifiche jaso api per motori raff. ad aria ...... una precisazione : mi riferisco al mio Kolm versione canna riportata in acciaio ..... i nuovi hanno cilindro in alluminio e trattamento nicasil...... quindi dovrebbero scaldare molto meno.....
__________________ https://www.youtube.com/watch?v=0RLT...ature=youtu.be https://youtu.be/lepHh1qHFEA https://www.youtube.com/watch?v=lx4Z...GQBNJf6f7RjNcA Ultima modifica di GiorgioDDT : 24 luglio 17 alle ore 13:56 | |
![]() | #314 (permalink) Top | |
User Data registr.: 01-01-2008 Residenza: montagnana (pd)
![]() | #315 (permalink) Top | |
User | Citazione:
A prescindere dall'olio, non so che Saito possiedi... comunque occhio alla % perchè ad esempio sui stellari le bielle non hanno cuscinetti ma bronzine. | |
![]() | #317 (permalink) Top |
User | |
![]() | #319 (permalink) Top | |
User | Citazione:
![]() | #320 (permalink) Top |
User Data registr.: 26-12-2008 Residenza: PORDENONE
Secondo me va bene un qualsiasi buon olio sintetico o semisintetico,le nostre sensazioni sono spannometriche e fanno poco testo,io per il rodaggio uso sempre olio sthill HP che dovrebbe essere un minerale e lo uso solo per questo motivo,sthill vende anche l' HP ultra che è un sintetico ma se andiamo a vedere sia l'uno che l'altro sthill lo consiglia per tutti i suoi attrezzi sia che facciano 18000 giri come le motoseghe sia per decespugliatori che ne fanno meno della metà (ho chiesto al rivenditore sthill) inizialmente ho usato il motul 800 off. ora uso il bardhal ktx quest'ultimo lo preferisco solo perché non viene fuori nero dallo scarico e vedo l'aereo meno imbrattato ma sinceramente non so se questa differenza è un bene o un male per il motore quindi ?
__________________ PER FARSI DEI NEMICI NON E' NECESSARIO DICHIARARE GUERRA. BASTA DIRE QUELLO CHE SI PENSA (Martin Luther King) |
yankee europa 89 | teorr | Automodellismo Vintage | 49 | 23 aprile 14 18:44 |
Inizio a disegnare lo Yankee Doodle | rasghi81 | Aeromodellismo Alianti | 0 | 28 luglio 10 17:29 |
