Vecchio 23 ottobre 11, 12:51   #21 (permalink)  Top
L'avatar di at-6 harvard
Data registr.: 01-02-2008
Residenza: Firenze
Immagini: 5
thks Gabriell. I state that I am not a lover "vintage" but I realize that the "old timers airplane" have a little something extra 'that have no modern reproductions, that is loyalty in detail "a true miniature airplane". however, when the reproductions are made ​​by expert hands then this enhances them even more.
p.s when i come in Germany i call you ok?.. see you soon
at-6 harvard non è collegato   Rispondi citando
Vecchio 23 ottobre 11, 13:11   #22 (permalink)  Top
Data registr.: 04-10-2011
Hello at-6-harvard,
yes ok, please tell me if you come to Germany.
I will show the next parts.
The first photo shows the finished elevator.
The wire edge will come later.
Pic.2 + 3
You can see the control with the pedals.
have fun, greetings gabriel
Gabriel Voisin non è collegato   Rispondi citando
Vecchio 23 ottobre 11, 14:40   #23 (permalink)  Top
As promised, here new pictures.
Figures 1. shows the control with steering wheel. After painting, the part is installed.
Figures 2 and 3 shows the glued wing.
Greetings Gabriel
Vecchio 23 ottobre 11, 15:00   #24 (permalink)  Top
L'avatar di snioff
Data registr.: 28-12-2007
Really wonderful!
snioff non è collegato   Rispondi citando
Vecchio 23 ottobre 11, 16:05   #25 (permalink)  Top
Thanks so much, snioff.
I've grinded and mounted the wings.
Greetings Gabriel
Ultima modifica di Gabriel Voisin : 23 ottobre 11 alle ore 16:08
Vecchio 23 ottobre 11, 16:28   #26 (permalink)  Top
Hello together,
At one of my photos you can see my "helping hand", for the soldering works of the pipe clamps.
This is absolutely necessary to produce some pipe clamps and to solder them.
A very simple construction made of a 3mm aluminum wire, but is very helpful.
The brass tubes was slotted and then I inserted the clamp in the slot and soldered.
All holes through the wing spars, I reinforced with 1mm thick pine strips. So they do not break.
I wish you much fun and a good week.
Greetings Gab
Vecchio 23 ottobre 11, 23:51   #27 (permalink)  Top
L'avatar di snioff
Hi Gabriel, did you produce some video tutorials on youtube meanwhile you are welding or some pictures of topic welding moments? Understand me, not a matter to go over your privacy but just to learn how you arrange your work-space when you make such a superb job like you did.
Tky in advance.
Vecchio 24 ottobre 11, 00:41   #28 (permalink)  Top
Hi snioff,...thanks.
Sorry, I've made not any videos because I have not a video camera.
greetings gabriel
Vecchio 25 ottobre 11, 00:36   #29 (permalink)  Top
It’s ging on.
Greetings Gabriel
Vecchio 25 ottobre 11, 01:40   #30 (permalink)  Top
L'avatar di Mrk89
Data registr.: 29-05-2006
Residenza: Catania
Truly impressive!!
Perfect job Gabriel!!
Il filo attaccato all'antenna non mente mai....Troppo vento, si torna a casa....
I miei circuiti elettronici autocostruiti: Postbruciatore per ventole intubate ; Circuito luci per aeromodello-elimodello ; Rallenta servo con protezione da corto circuito
Mrk89 non è collegato   Rispondi citando
Persentazione F4J Volo "Scale" EnzoG Aeromodellismo Turbine 2 14 agosto 11 17:32
Recensione: Hyperion PIPER CUB "25e" Super Scale ARF - BUSH PILOT EDITION not103 Aeromodellismo 2 03 gennaio 11 19:48
Build log: Reggiane RE.2005 "Sagittario" in balsa SlowFlyer Aeromodellismo Progettazione e Costruzione 385 01 luglio 09 14:21
Kit Modello P51 D MUSTANG "25" Super Scale - HYPERION razorOne Aeromodellismo Volo Elettrico 19 01 febbraio 08 12:08
Tutti gli orari sono GMT +2. Adesso sono le 13:39.
