Vecchio 12 marzo 07, 14:47   #11 (permalink)  Top
L'avatar di mugneto
Data registr.: 16-09-2006
Residenza: piacenza
...vabbè...finite le scorribande cinesi , sono passato un attimo a Singapore e ho trovato questo , tra spedizione Airmail ed oggetto dovrebbe costare 35 eurini circa...
...ne ho visti anche altri, non marchiati Multiplex, ma assolutamente identici, anche nelle "prestazioni"...mah...che dite ?
Filippo
"Amo molto parlare di niente. É l'unico argomento di cui so tutto.
(O.Wilde) "
mugneto non è collegato   Rispondi citando
Vecchio 12 marzo 07, 15:24   #12 (permalink)  Top
L'avatar di Robby Naish
Data registr.: 16-10-2002
Questo
è fantastico
peccato che se non posso usare il pc, il display costa altry 50 euro!!!
Logs pack current to +/- 100 amps and voltage from about 4.5 volts to 45 volts
Current is measured with a true Hall Effects Sensor - NOT a resistance shunt!
Great for bench monitoring of battery charging also!
NEW: Accepts optional inexpensive sensors for Temperature, RPM (brushless, magnetic or optical), Airspeed, Altitude, Servo Current, Throttle Movement, and more, available below
All data is logged to permanent memory, which retains the data even when the power is removed
Software computes Wattage, mAH, etc. for complete e-flight data.
Fully Compatible with Windows Vista, 98SE, ME, Win2K and XP™
Integrated USB with included cable (NOT a USB to serial port cable like other loggers)
Supports simultaneous Temp and RPM sensors, or two Temps
Weighs about 0.5 oz (17 grams). Version with Wire Leads weighs slightly more.
Supports USB Live Mode, which lets you see what's happening in the model LIVE on the bench, on your PC
Adjustable logging rate (1-10 samples/second) and lossless data compression for long log times
Comes with our state of the art Windows virtual playback display and graphing
Powerful Graphing software has advanced charting features, such as amps vs volts
Internet Updatable firmware - as we add new features or (heaven forbid) have a firmware bug, the update is just a download away! No need to ship hardware back and forth.
Full support for English and Metric units
The MicroPower system comes with everything you need to log current and voltage, right out of the box (logger, USB cable, CD, manual).
Add-on
1) NEW: Brushless Motor RPM Sensor (RPM-KIT-BRS)
Tiny sensor measures RPM by simply connecting a wire from one of your brushless electric motor leads to the sensor. This connection is just a tap (not inline) which simplifies installation.
2) NEW: Altimeter Expander (MPR-ALT-EXP)
High resolution Altimeter measures Altitude from 0-8000 feet (0-2400m) with 3 foot (1 meter) or higher resolution
3) Airspeed Expander (MPR-AIR-EXP)
Measures airspeed from 0-200 MPH.
4) Multi-Expander (MPR-MULTI-EXP)
Expands your MicroPower to support Brushless RPM, Throttle movement recording, and simultaneous recording of two temperatures. Includes integrated Brushless RPM sensor and Y cable for Throttle monitoring. Temperature sensors sold separately below.
5) Micro Temp Sensor
(TEMP-MICRO)
Perfect for measuring temps of your batteries and ESC. 250 degrees F max temp.
Up to two temperature sensors can be connected to the MicroPower simultaneously. Temperature Sensor (TEMP-LOOP)
Loop-around temperature sensor measures temp up to 420 degrees F. Great for looping around motors.
ci devo fare un pensierino
Alex
Robby Naish non è collegato   Rispondi citando
Vecchio 12 marzo 07, 22:32   #13 (permalink)  Top
L'avatar di mugneto
Residenza: piacenza
magnifico !
ma effettivamente troppo per il mio elettrone spaiato...!!!
In uno dei miei negozi online preferit, cioè qui, vendono anche questi ,ma ripeto...sono troppo per me.......
Filippo
(O.Wilde) "
Vecchio 12 marzo 07, 22:33   #14 (permalink)  Top
Da oggi su UH 55 euro spedito
Alex
Domandina su assorbimento f.alberto Aeromodellismo Volo Elettrico 13 04 aprile 07 10:41
assorbimento servi Grimaldello Elimodellismo Motore Elettrico 0 09 gennaio 07 23:48
Assorbimento servi speedy Aeromodellismo 18 14 luglio 06 13:10
assorbimento statico comet Aeromodellismo Volo Elettrico 3 07 febbraio 06 18:28
Assorbimento max Hacker B40 aleall Aeromodellismo Volo Elettrico 0 21 novembre 05 18:26
Tutti gli orari sono GMT +2. Adesso sono le 09:04.
