Vecchio 05 dicembre 06, 12:19   #1 (permalink)  Top
Data registr.: 05-12-2006
Residenza: Nola (NA)
Primo Acquisto
Ho già fatto un bel pò di simulazione e mi accingo a comprare un trainer elettrico. Dopo un pò di ricerche sono approdato da happitoy.com e scelto il seguente materiale:
1) Walkera 180L Brushless Motor + 30A ESC + 2200 Mah Li-po
Specification Specification of the Walkera 180L Brushless Motor (3200KV)
- Dimension: ?X 20 X 40mm
- Speed constant (KV): 3200RPM/V
- Working voltage: 6-18v
- Shaft extension: 13.5mm
- Shaft diameter: ?X 2.0mm
- Weight: 65g
Specification of the Walkera Electronic Speed Controller (30A)
- Sustaining voltage: 6-17v.
- BEC current: 3.0A
- Continuous output current: 30A
- Instant max current: 50A
- Inside impedance: 0.0044 ?[
- Reversion: yes
- Low voltage, cut electricity protection: yes
- Size: ~ 60mm X 26mm X 7mm
- Weight: ~ 32.4 g
Specification of the 3e Model Li-Polymer (11.1v., 2200mah, Black)
- Discharge Rate: 10C
- Flying Time: Over 25 minutes (Continuously)
- Charge Time: ~ 60 minutes
- Charger function: Auto off
- Voltage: 11.1v.
- Mah: 2200
- Size: ~ 72mm X 40mm X 27mm
- Weight: 170g
Specification of the Li-Polymer Charger (12.6v., T-Shape)
- Charger for 11.1v. Li-polymer battery
- Input: 110v.-220v.
- Output: 12.6v.
- For T-Shape style Li-polymer battery plug
- Color: Black
- Type: Europe, UK, US,Australia plug available
1) 601 RC-Power BC charger
Microprocessor controlled high-performance Rapid charger for NiCd/NiMH/Li-polymer/Li-ion/Pb batteries
- Include USB communicated analysis,(Monitor software supported). Temperature sensor and separate voltage detector for balance charge mode.
- High-power and high-performance circuit
- Optimized operating software
- Maximum safetyelta-peak sensitivity/Capacity limit/Temperature limit/Processing time limit/Input power monitor/Automatic cooling fan
- Monitoring the voltage of individual cell
- Data store/load
Specification - Li-lon/Polymer battery:1-5 series
- NiMH/Ni-Cd battery:1-14 cells
- Lead acid(Pb):6-12V
- Charge/Discharge cycle:1-5
- Charging rate:0.1A-5.0A; Discharger rate:0.1A-2A
- Battery memory:10 models; USB PC Link;
- AC-DC adopter; Multifuctional battery connector
4) X 9g 230mm Mini Servos for Helicopter & Airplane
Specification -Weight: 9g
-Operating speed: 0.11 second / 60 degree (4.8v)
-Stall torque: 2.0kg/cm
-Temperature range: -30?J~60?J
-Dead band width: 2ms
-Operating voltage: 3.0v - 5.0v
-Connector wire length: 150mm
-Dimension: 26mm X 13mm X 24mm
1) EPP SU-31 4 Channel Airplane Kit
Specifications:
1) Wingspan: 820mm
2) Overall length: 840mm
3) Total surface area: 21.5DM
4) All-up weight: 280 - 350g
per un totale di 217 € compreso spedizione.
Ho già la radio Futaba T6EXA e uno SkyRaider con un OSLA46 che farò volare solo quando ho una buona pratica con un eletrico.
Chiedo cortesemente un giudizio sulla merce , fornitore , etc.
Sul modello ho tanti dubbi , è simile all' ucando e non credo sia tanto resistente . Vorrei quancosa che mi permetta di fare qualche acrobazia ma sia anche resistente e ben controllabile.
Grazie mille
Antonio
Ultima modifica di atsoft : 05 dicembre 06 alle ore 12:22
atsoft non è collegato   Rispondi citando
Il primo acquisto Pippo2707 Elimodellismo Principianti 1 22 novembre 07 23:10
primo acquisto sieben Aeromodellismo Principianti 14 10 aprile 07 15:46
primo acquisto neonov Automodellismo 16 30 settembre 05 15:39
Primo acquisto Poni Aeromodellismo Principianti 4 08 febbraio 05 10:46
primo acquisto Davide LS Aeromodellismo Principianti 41 26 novembre 04 11:01
Tutti gli orari sono GMT +2. Adesso sono le 06:50.
