27 luglio 06, 00:12 | #72 (permalink) Top | |
User Data registr.: 06-03-2005 Residenza: Trento
Se il file avesse un altro formato dovrebbe esserci una applicazione per trasformarlo in .IGC. Ciao Gallina | |
27 luglio 06, 00:24 | #73 (permalink) Top | |
UserPlus Data registr.: 14-04-2005 Residenza: Verona
Questo è quello che c'è scritto nel link che ho postato: Data Log Switching to the Data Logger tab allows you to enable/disable the data logger, setting the constant distance in meters and constant time, speed limits to be tripped, and whether to include altitude information within the logs. All of this information gets written to flash memory, and can be set to overwrite the oldest data when full or to stop logging when full. Downloading the data is very easy, and can be done by selecting the Download tab, change the mode to Download and Delete, select a filename to save to and whether to process data after download. Switching to the Processing tab, will again give you the filename, which data to process, or the working time to process and allow you to convert the data to an NMEA file. When converting to NMEA, you'll be prompted for which features to select, e.g. RMC, GGA, GLL, VTG. The great feature about data log playback is you set the COM port to act as a GPS, and play back the data, and execute a GPS application and see the data within your application to effectively replay a route in real time. The same features in the RoyalTek Blue GPS Application are available for both PC and Pocket PC versions of the program.
__________________ RC PLANES ARE NOT DRONES | |
27 luglio 06, 00:36 | #74 (permalink) Top |
UserPlus Data registr.: 27-05-2004
già, non ci avevo fatto caso... scusami! cmq guardatevi questo video di prova dell'eagletree http://static.rcgroups.com/forums/at...HlEatgoKZgq767 |
27 luglio 06, 10:20 | #76 (permalink) Top |
prova ad arriv arci da qui: http://www.rcgroups.com/forums/showthread.php?t=538633 ci sono 2 video + recensione |
07 agosto 06, 16:03 | #77 (permalink) Top |
Per chi si fidasse ad infilare telefono e ricevitore nel modello.... http://www.realtrackmobile.com/index...cat=1&idpro=17
08 agosto 06, 23:40 | #80 (permalink) Top |
User Data registr.: 14-05-2005 Residenza: Camisano vicentino
....rischia ogni volta il cellulare e il gps.... Anche se mi sa che gli porta fortuna visto che quando l' ha tolto ha distrutto il trainatore.... Cmq anche se il sistema si limita solo a registrare non è una brutta idea visto che quando atterri vedi subito tutti i dati.... secondo me il metodo migliore è un ricevitore gps bt potenziato e palmare o cellulare a terra.... appena torno a scuola provo a chiedere ad un mio amico professore se ha qualche idea.... |
Altimetro ed anemometro | staudacher300 | Aeromodellismo Alianti | 4 | 28 dicembre 07 23:42 |
altimetro | almebrigo | Aeromodellismo Progettazione e Costruzione | 1 | 23 gennaio 07 18:16 |
Costruire un altimetro/variometro | airdavide | Circuiti Elettronici | 6 | 10 dicembre 06 10:56 |
Altimetro | OttObismark | Aeromodellismo Alianti | 54 | 05 dicembre 05 23:35 |
