28 settembre 08, 20:53 | #121 (permalink) Top | |
User | JW tip twist Citazione:
Com'è che non sei ancora registrato su RCgroups ??? OK, ok, ecco il cut&paste : Private Message: Re: JW54" tip twist ?? Yesterday, 10:14 PM Joe W JW Join Date: Dec 2004 Posts: 230 Re: JW54" tip twist ?? -------------------------------------------------------------------------------- Ummm... Not sure whether there is a rational reason for the twist on the old 54" Jaydub... The original design evolution of the JW airfoils was that the airfoils were designed for the Sonic that Pat Bowman was kitting. This was a flying wing with sweep, similar in planform to Zagi, etc. The aerodynamic effects of sweep required washout due to the outward movement of lift that that sweep causes. Pat came up with the unswept JW via just taking the sweep out of the Sonic and still using the same washout. Later versions took out the washout if I remember correctly. The above is from distant memory, hopefully I am not making mistakes in my memory! Regards, Joe PS I still love flying a clean JW, it is has the best +/- flight characteristics. Might not be the absolute fastest for ds, but definitely has the best handling qualities for DS acro! Quote: Originally Posted by andreis Dear Joe, Sorry to contact you directly, I hope it doesn't disturb you so much . I'm in discussion with several slope friends about tailless mainly about Plank, with such enfatization on JW overall performances and flexibility, as about its own design choices, see also Here in Italy (I'm live in Monza, where the F1 race...) there is a small JW comunity spreaded on all the territory, and the JWs are meeting even frequently, both to flying all together, and to discuss about its unuque characteristic. The question of the day is : wich were the reasons that suggested you to twist the tip cords of the first JW54" version, and why the leates JW60" version doesn't has any ttip twist ??? I'm a proud and veery satisfied owner of a JW60" sligtly enlarged to 64" . Of course any further comment on the argment will be very apreciated. Many thanks, best regards, and ciao, Antonio Andreis Via Gadda, 1 20052 Monza ITALY phone +39 346 8314291 Antonio. | |
28 settembre 08, 20:58 | #122 (permalink) Top | |
User | Citazione:
Antonio. | |
28 settembre 08, 21:25 | #123 (permalink) Top | |
Gran Decapo Data registr.: 18-03-2007
Questo mi solleva molto. | |
28 settembre 08, 22:46 | #124 (permalink) Top |
User | Personalmente, non avevo più di tanti dubbi che la cosa avesse potuto essere andata così. E una mezza idea, ma realistica l'avevo già buttata giù su questo thread. D'altronde sembra essere una consuetudine, il fatto che si prende ciò che di buono è stato fatto da alcuni così com'è personalizzandone solo alcuni aspetti................ Pensa che oggi ho ricevuto una confidenza all'uccellino, e in particolare che persino il JP ha avuto la stessa sorte ... JP = JoePers Stesso taglio ali del Polistrali, fatto dal kit-maker con freccia zero, quindi con la svergola che c'è rimasta dentro, tale e quale che sul modello a freccia. Antonio. |
29 settembre 08, 08:03 | #125 (permalink) Top | |
29 settembre 08, 08:38 | #126 (permalink) Top | ||
User Data registr.: 24-02-2007 Residenza: Bergamo
Esti... Circa la qualita'... cosa vuoi pretendere quando le cose nascono con lo scopo di togliersi dai piedi prima possibile 2 "ragazzacci"... prendi un Polistirali e gli raddrizzi le ali e per sovraprezzo gli regali un abbassamento di profilo al 10%.. Con poco rendi felici le persone... il peggio e' che continuano a chiederlo.. Sergio | ||
29 settembre 08, 11:14 | #128 (permalink) Top | |
User | Citazione:
Ma il nostro è un piccolo mondo fatto "quasi" tutto così, tutti vogliono e/o chiedono nuovi giochini che facciano cose sempre diverse e nuove ...., ma tranne rari casi, nessuno si chiede perchè le cose son fatte e vanno in un determinato modo, come migliorarlo, modificarlo, otimizzarlo, ecc..... Antonio. | |
29 settembre 08, 12:34 | #129 (permalink) Top | |
User | Citazione:
Si sa mai che ogni tanto ne resti invischiato qualcuno in più a metterci un po' del proprio...... So bene di essere ancora parecchio "impacciato" su certi argomenti, ma mi piacciono e mi diverte disquisirci, come provare e sperimentare di persona (per quel che posso e riesco....) Antonio. | |
Tuttala | Nirvana76 | Aeromodellismo Progettazione e Costruzione | 3 | 14 novembre 08 14:43 |
Tuttala | twentynine | Aeromodellismo Progettazione e Costruzione | 9 | 27 aprile 05 11:25 |
tuttala | alextuono | Aeromodellismo Volo Elettrico | 3 | 27 febbraio 05 23:26 |
tuttala | alextuono | Aeromodellismo Principianti | 8 | 22 febbraio 05 21:34 |
Tuttala | Canard4ever | Aeromodellismo | 2 | 24 febbraio 02 20:54 |
