Ciao, io ho dei brushless da 3,5gr 4500KV a cassa rotante
Queste sono le caratteristiche:
* Micro Outrunner Motor 3.5g for 7.4V
* Battery pack 2 cells lithium polymer
* Current 2 Amp continuous
* Configuration 10/3/26 Y (10mm dia/3mm length/26 turns)
* Connection Y (also known as Star)
* Kv 4500 rpm per Volt
* Prop (direct drive) 4" x 2.5" or 5" x 3" GWS
* Output 33200 rpm ±5%
* Thrust 25.8g
* Weight 3.5g / 0.13oz
* Stator diameter 10mm
* Stator length 3.0mm without shaft or mount
* Shaft diameter 1.5mm
Io non ho tempo di provarli pensate possano andare bene?
