Ecco le caratteristiche degli ino-lab ...penso che 2,5 kg (X3) sul ciclico del 500ino non siano male ....e la velocità non è da meno
HG-D260HB DIGITAL SERVO
TECHNICAL DATA
CONTROL SYSTEM: PULSE WIDTH CONTROL
OPERATING VOLTAGE:
4.8V ~ 6.0V
OPERATING TRAVEL: 30°/ ONE SIDE PULSE TRAVELING 370usec
DIRECTION: COUNTERCLOCKWISE/ PULSE TRAVELING 1500 TO 1870
TEST VOLTAGE: AT 4.8V AT 6.0V
OPERATING SPEED:
0.12s/60° 0.10s/60°
STALL TORQUE:
2.4Kg.cm(33.32oz.in) 3.4Kg.cm(47.21oz.in)
DYNAMIC TORQUE:
2.0Kg.cm(27.77oz.in) 2.5Kg.cm(34.71oz.in)
DEAD BAND WIDTH: 2us
FEATURES
AMPLIFIER TYPE: DIGITAL PULSE WIDTH CONTROLLER & FET DRIVER
LONG LIFE POTENTIOMETER: 500,000 cycles
MOTOR TYPE: COLED METAL BRUSH 3POLE MOTOR
TOP BALL BEARING: MR106 BALL BEARING
GEAR MATERIAL: HEAVY DUTY CARBONITE GEARS
HORN GEAR SPLINE: 25 SEGMENTS/ Ø5.96(FUTABA TYPE
SPLINED HORNS: 4 CLASS
CONNECTOR WIRE LENGTH: 270mm(10.63in)
CONNECTOR WIRE STRAND COUNTER: 0.08mmx30EA
DIMENTIONS
