il mio Gemini è ancora in cantiere ...
ecco il motore che monterò per una configuraziuone in acrobatico ....
SCORPION 3008-28
tator Diameter ............................ 30.0 mm (1.181 in)
Stator Thickness ............................. 8.0 mm (0.315 in)
No. of Stator Arms ................................................ 12
No. of Magnet Poles ............................................... 14
Motor Wind ........................................... 28 Turn Delta
Motor Wire ...................... 10-Strand 0.19mm (32 AWG)
Motor Kv ........................................... 1253 RPM / Volt
No-Load Current (Io) ................................. 1.53 Amps
Motor Resistance (Rm) ............................. 0.072 Ohms
Max Continuous Current ............................... 30 Amps
Max Continuous Power ................................ 400 Watts
Weight ........................................ 85.5 Grams (3.02 oz)
Outside Diameter ......................... 37.50 mm (1.476 in)
Shaft Diameter .............................. 4.97 mm (0.197 in)
Body Length .................................. 25.9 mm (1.019 in)
Overall Shaft Length ....................... 64.5 mm (2.539 in)
C1a0
