Qualcuno ha provato o sà come va questo motore con le quattro celle ?:
Electrifly Ammo 28-45-3600
Motor Diameter 28 mm
Motor Length 45 mm
Shaft Diameter 3.2 mm
Shaft Length 15 mm
RPM / V (kV Rating) 3600
Bullet Connector 3.5 mm
Weight 4.6 oz. (133g)
Input Voltage 7.4-14.8 Volts
Maximum Constant Current 40 Amps
Maximum Constant Wattage 592
Maximum Surge Current 70 Amps
Maximum Surge Watts 1035 Watts
No Load Current 2.3 Amps
Internal Resistance 18.9 mOhm
C1a0
