Originalmente inviato da OlandeseVolante Cosa ne dite di questa?
RCHH-500 - Walkera Upgrade Li-Po Battery
NEW! 500MaH Up Grade Li-Po Battery for Walkera 4#3 Helicopters and any of the MIA Framesets
Single cell Lithium Polymer 500MaH Battery.
10c Continuous Discharge rate of 5 amps with 7.5 amp bursts.
Dimensions: 5mm x 22mm x 56mm.
Weight:11 grams same as stock 4-3 400mah battery.
This Battery fits perfectly under any of the MIA Framesets!
Available 5-07-08 Product Listing Batteries |
Io vorrei provare queste :
HYPERION Li-Poly LVX 400 mA 2s1p - 7,4 V 20C/40C #16489
FlyModelComponents :: Batterie Polimeri Litio :: HYPERION SERIE LVX 20C - 30C/40C LiteStorm Voltage Xtreme :: HYPERION Li-Poly LVX 400 mA 2s1p - 7,4 V 20C/40C
da spacchettare ovvio ;)
