Ragazzi mi è arrivata sta mail oggi ke vuol dire :
Other order items:
1 x HPI-HP4456(HPI Yokohama Geolandar M/T Tire S Compound (2)) * Pending
1 x HPI-HP86900(HPI Slipper Pad (2Pcs) Firestorm) * Pending
1 x RWX-RW4800-21(RW 48 DP Pinion 21 teeth) * Pending
1 x HPI-HP86946(HPI Spur Gear 87T (48 Pitch) E-Firestorm) * BackOrder
1 x HPI-HP86902(HPI Wheel Washer 5x14x2mm (8Pcs) Firestorm) * BackOrder
1 x RWX-RW4800-22(RW 48 DP Pinion 22 teeth) * Pending
1 x RWX-RW4800-20(RW 48 DP Pinion 20 teeth) * Pending
1 x ORI-ORI22039(Orion SV2 Formula Pro-BB 17x2) * Pending
* We regret that we are currently out of stock of the items marked BackOrder.
These items will be held on back order and despatched as soon as possible. Despatch times are typically within 7 days but depend on the availability of the item from its supplier.
Card Payments only - please note you will not be charged any additional carriage, and your payment card will not be debited until the back order is processed. You will be sent further email notification when the back order is despatched.
* The items marked Pending have been allocated for you and will be despatched when your order is complete.
Team C TM2V2 : Xerun V3-Xerun 8.5T-Savox 1257
