BaroneRosso.it - Forum Modellismo - Visualizza messaggio singolo - Servi Alternativi, chi li ha provati
Vecchio 07 aprile 08, 14:22   #1 (permalink)  Top
honey_bee
L'avatar di honey_bee
Data registr.: 10-12-2006
Invia un messaggio via MSN a honey_bee
Chi ha provato servi alternativi ai soliti futaba?
Girando in rete ho torvato i cinesi
towerPro TowerPro MG995 Servo
http://www.rcsmart.com/images/servomg99501.jpg
- Dimensions: 1.57" x 0.79" x 1.44" (40 x 20 x 36.5mm)
- Weight: 1.78oz (48g)
- Operating Speed (4.8V no load) : 0.17sec / 60 degrees
- Operating Speed (6.0V no load) : 0.13sec / 60 degrees
- Stall Torque (4.8V): (13kg/cm) (180oz/in.)
- Stall Torque (6.0V): (15kg/cm) (208oz/in.)
- Temperature Range: -30 to +60 Degree C
- Dead Band Width: 4usec
- Operation Voltage: 3.5 - 8.4Volts
Model: HD-9150MG
http://www.pitstop-shop.nl/media/hd9110_0030_8.jpg
Voltage: 4.5v~7.2v
Speed: .17sec
Torque: 15.8kg/cm
Bearings: 2BB
Gears: Metal
Weight: 60g
Model: HD-9110MG
Voltage: 4.5v~7.2v
Speed: .19sec
Torque: 10.5kg/cm
Bearings: 2BB
Gears: Metal
Weight: 49g
MG996R
http://www.hobbycity.com/hobbycity/s...log/MG996R.jpg
This is essentially an upgraded version of the famous towerpro MG995 servo. It now has a redesigned PCB and IC controll system which makes it far more accurate. Its internal gearing and motor are also upgraded to improve dead bandwith and centering.
All specifications are the same as the previous model MG995, however this servo is far more accurate, and safe to use in aircraft which require precise servo movements and perfect centering.
Weight- 53.0g
Dimension 40.7*19.7*42.9mm
Stall torque 10kg/cm
Operating speed 0.20sec/60degree(4.8v)
Operating voltage 4.8-7.2V
Temperature range 0Ž_ 55Ž
Servo Plug: JR (Fits JR and Futaba)
honey_bee non è collegato   Rispondi citando
