Vecchio 10 giugno 05, 11:12   #9 (permalink)  Top
odisseablu
L'avatar di odisseablu
Data registr.: 22-12-2004
Residenza: milano
Outrunner Brushless Motor Description:-
- 100% Brand New
- Size: Dia. 31mm x 29mm (not include the shaft)
- Shaft Dia: Standard threaded 3 mm Shaft (suitable for GWS props etc.)
- Weight: 56g(with the plastic mount)
- Weight: 49g(without the plastic mount)
- Max Current: 15 Amps (Recommend using the 18A Brushless ESC)
- Input Voltage: 7.2-12V suitable for 2 cells or 3 cells Lipo.
- KV: around 1500RPM/V
- Suitable for Props: 6x4, 7x3, 7x4 or 8x4, etc.
18A Brushless ESC Description:-
- Size only 40 x 25 x 10mm.
- Weight only 20g.
- Input Voltage from 7.2V to 12V, suitable for both NiMH and Lipo batteries.
- Current Limit 15A continuous, max.18A within 5 sec.
- Automatic detect the cut-off voltage when you connected the batteries.
- Can be programmed to switch the brake ON / OFF
- Suitable for JR/Futaba/Hitec/GWS.
questi i dati tecnici del motore e del regolatore
Stefano vola alto !!!
Quando non si schianta al suolo !!!
Buoni voli e felici atterraggi
odisseablu non รจ collegato   Rispondi citando
