ho torvato i dettagli tecnici del motore del ruslter vxl
Velineon 3500 Specifications:
Type.............................................. .............................................Senso rless brushless
RPM/volt.............................................. ................................................ 3500 (10-turn)
Magnet type.....................Ultra High-Temperature Sintered Neodymium
Connection type.............................................. TRX 3.5mm bullet connectors
Wire size.............................................. ...............................12-gauge Maxx® Cable
Current Ratings........................................... ... 65A constant; 100A peak/burst
Max RPM............................................... .................................................. ............. 50,000
Diameter.......................................... ................................. 36mm (1.42) (540 size)
Length............................................ .................................................. ... 55mm (2.165)
Weight............................................ .................................................. ......262g (9.24oz)
