I regolatori JETI hanno dei parametri impostabili con dei jumper...
Codice:
Mode 1: NiCad/NiMH Brake Off
Non-active brake with slow down type low voltage cut-off down to 5 volts or 0.7 volts per cell.
Mode 2: NiCad/NiMH Brake On
Active brake with hard type low voltage cut-off at 5 volts or 0.7 volts per cell.
Mode 3: LiIon/LiPoly Brake Off
Non-active brake with slow down type low voltage cut-off. Minimum voltage 6 volts for 2 cell packs, 9 volts for 3 cell packs.
Mode 4: LiIon/LiPoly Brake On
Active brake with hard type low voltage cut-off. Minimum voltage 6 volts for 2 cell packs, 9 volts for 3 cell packs.
Sicuro di non aver sbagliato qualcosa?
