Vecchio 14 gennaio 08, 17:03   #25 (permalink)  Top
newyork
Data registr.: 12-08-2006
Torque Control™ Slipper Clutch
The Torque Control slipper clutch uses special semi-metallic friction material and finned aluminum alloy pressure plates to dissipate heat and provide consistent traction control. The semi-metallic friction material remains stable across a wide temperature range to provide smooth, linear engagement you can count on, lap after lap. Spur gears can be removed and replaced without altering the slipper adjustment. A center ball bearing maintains precise, long-lasting alignment with near friction-free running and virtually zero maintenance. Originally developed for Revo, the Torque Control slipper is more than tough enough for Jato. Only Traxxas has it!
michele
newyork non è collegato   Rispondi citando
