Vecchio 11 gennaio 08, 13:58   #7 (permalink)  Top
pablo000
L'avatar di pablo000
Data registr.: 11-09-2007
Residenza: Pesaro
Originalmente inviato da dema80
scusami ma non vedo ne video ne foto e purtroppo non so l'inglese..
e si haio proprio ragione sono un disastro....
aiutooooooooooooooooo
è una pagina di un forum .... e il primo mess ha queste scritte:
Video Link ->What's in the box!! (14 Megs)
Video Link ->Step 1 - Head and Grip Assembly (48 Megs)
Video Link ->Step 2 - Seesaw and Flybar Assembly (85 Megs)
Video Link ->Step 3 - Swash Plate and Washout Assembly (24 Megs)
Video Link ->Step 4 - Main Gear and Engine Clutch Assembly (38 Megs)
Video Link ->Step 5 - Main Frame Assembly (85 Megs)
Video Link ->Step 6 - Mounting the Fan, Clutch and Governor Magnets (57 Megs)
Video Link ->Step 7 - Mounting and setting up the GV1 and ATG / TJ Pro Gov Sensors (66 Megs)
Video Link ->Step 8 - Installing the Motor and Fan Shroud (28 Megs)
Video Link ->Step 9 - Installing The Servo Bellcranks (33 Megs)
Video Link ->Step 10 - Servo Installation (30 Megs)
Video Link ->Step 11 - Servo and Bellcrank Setup (80 Megs)
Video Link ->Step 12 - Fuel Tank and Fuel lines (56 Megs)
Video Link ->Step 13 - Throttle Servo install and setup (48 Megs)
Wow the GV-1 took me some time to get right. Several reshoots etc. I wanted to give you all the MOST info about it's use as possible. Anyway this one is in 2 parts!
Video Link ->Step 14 - Part 1 / GV-1 Overview and base radio setup (50 Megs)
Video Link ->Step 14 - Part 2 / GV-1 Menus and setup (60 Megs)
Here is a neat tip I figured out. How to make a throttle cut switch for a DX7 radio!
Video Link ->How to set up a Throttle Cut Switch on a DX7 radio (23 Megs)
OK here is the Curtis ATG gov setups. Easier to setup than a GV-1 and is much like the TJ Pro. ALSO some might want to watch part 2 as a show a neat trick to get 3 RPM's tied to your idel up switch! This would be helpful to TJ Pro users as well!!!
Video Link ->Step 15 - Part 1 / Curtis ATG Overview and base radio setup (43 Megs)
Video Link ->Step 15 - Part 2 / Curtis ATG setup and how to setup a DX7 for 3 gov RPMs tied to idle up switch! (60 Megs)
Video Link ->Step 16 - Tail Drive and Tail Assmebly (48 Megs)
Video Link ->Step 17 - Torque Tube and Tail Boom Installation (57 Megs)
Video Link ->Step 18 - Tail Servo with GY601 and Tail Control Linkage Setup (48 Megs)
Video Link ->Step 19 - Head and Head Linkage Setup (39 Megs)
Video Link ->Step 20 - Electronics Placement (35 Megs)
Video Link ->Step 21 - Landing Gear (15 Megs)
cliccando su ognuna ti scaricherai un video dedicato al montaggio di ogni singola parte ... unica cosa per poter accedere ti devi registrare a quel forum!!!
pablo000 non è collegato   Rispondi citando
