mi sembra che sia questo:
yes, You have to open the LP5DSM Tx, and on the bottom board (where the DIP switchers are located) there with be a switch L --- R.
flick that switch and then you will have to move the auto-centering spring from the left stick to the right stick and move the little metal 'Groove-Grabber' from the right stick to the left. Wallah!!! you have switched modes!
