Originalmente inviato da Tamanaco |
I dati ufficiali Mega per il loro motore
Special brushless motor for aerobatic airplanes category F3A with 10S Li-Po batteries. Recommended too for big airplanes up to 10kg and scale gliders up to 20kg, 8-12S Li-Po or 24-32 Ni-Cd (MH) batteries. Propellers up to 22, current up to 60A.
Diameter: 44mm
Length: 120mm (without shaft)
Weight: 519g
Shaft diameter: 8mm (M8)
Efficiency: 88% (25-30A)
Resistance: 11mΩ
No load Rpm: 850 Rpm/1V
Gear ratio: 5:1
Rpm behind gearbox: 170 Rpm/1V
No load current: 1,4A (10V)
Recommended batteries: 8-12S Li-Po (24-38 Ni-Cd/MH)
Recommended prop: 18-22 (F3A APC-E 22x12 and 10S Li-Po)
Recommended controller: JES Advance 90 Acro (HV), TMM 9032-3
Quindi eliche a partire da 18 per arrivare alla 22
Motore da 8 a 12 celle
ACn F3A 8-12S Li-Po (24-38 cells. Ni-Cd/MH) 850 RPM/min/1V
170 RPM/min/1V behind gearbox 60 11 519
Buon Natale a tutti i lettori del Baronerosso Forum
Roberto
Electronicfly-rc
