Vecchio 03 dicembre 07, 23:51   #7 (permalink)  Top
babicka
Data registr.: 28-06-2005
eccoti il menù di programmazione:
SETUP MENU
First, connect the motor and receiver to the speed controller
Remove battery power from the speed controller.
Turn on the transmitter.
Move throttle stick on full power position,(UP Position)
Reconnect battery power to the speed controller
After 3sec you can hear (all sound is 3times)
— CELL Type AND Number
— — BRAKE
— — — TIMING MODE
— — — — PWM
ON you need programming menu, move the throttle stick to middle position.
1 CELL Type AND Number
•— NiMh/Nicd AUTO0.8V/CELL*
•— — 3LIPO 2.75V/CELL
•— — — 4LIPO2.75V/CELL
•— — — — 5LIPO2.75V/CELL
*IF used 2LIPO you can use the option .(select the NiMh/Nicd AUTO)
2 BRAKE
••— NO
••— — SOFT
••— — — MID
••— — — HARD
3 TIMING MODE
•••— 2 º
•••— — 7 º
•••— — — 15º
•••— — — — 30º
4 PWM
••••— 8KHZ
••••— — 16KHZ
••••— — — 32KHZ
IF the option is you need ,then move the throttle stick to UP position.
The long BEEP is save the option. and the system will go to the programming menu.
You can setup other options.
When all you need option is setup OK, push the throttle stick to down position, after 1sec the
system were save all option, then you can start the motor now!!
babicka non è collegato   Rispondi citando
