Originalmente inviato da xfifi Hello,I intend to speak about that on French forums. Thank you. |
Mine excuses bad English
The mm2007 in comparison to the 2001 has:
Easiest best position of the compoentis to be climbed on
Easier to dissipate the integrated ones
Presence Integrated for regenerating signals parallel "Bufferz"
good for portable computers
Double integrated to improve the part of the temperature thread cut
Version both from 1A and also from 8A
always in a sideburn from 100x160 mm eurocad
The same PIC of the MM2001 uses therefore 100% compatible
with GMFC Pro
It supports emergency and the future use of the limit switch
that will go out in the new versions of GMFC
If you look for in this discussion you find one video of mine of testing
http://www.saviot.com/Download/CollaudoMM2007.wmv
Be se qualcunaltro in lista sa tradurre meglio si faccia avanti
