Ciao a tutti,
datemi un consiglio, vorrei acquistare un monster truck, e stavo pensando in particolare a questo modello:
TRAXXAS REVO
In alternativa pensavo al
CEN GENESIS .46
Qui di seguito le caratteristiche del
TRAXXAS REVO:
Technische Daten:
Length: 19.125inches (486mm)
Front track: 16.125inches (414mm)
Rear track: 16.125inches (414mm)
Height: 10.375inches (264mm)
Wheelbase: 12.5inches (318mm)
Center ground clearance: 4.oinches (101mm)
Wheel Diameter: 3.8inches 97mm
Weight: 9.4 lbs
Motor: TRX-25R with Onboard E-Startermodul
Topspeed: +45mph
Url:
REVO
Qui invece le caratteristiche del
GENESIS:
Length: 23.1in. (587mm)
Width: 18.4in. (467mm)
Wheelbase: 15.63in. (397mm)
Weight: 17 lbs,(272 oz, 7.7kg)
Ground Clearance: 4 in. (111.8mm)
Suspension Travel: 4.4inch & 5 inch (w/o Top shocks)
Tire Size: 7.5in. (190.5mm)
Wheel Size: 5.2in. (132.1mm)
Fuel Tank Capacity: 220cc
Run Time: approximately 15 min
Url:
GENESIS
Ora ditemi la vostra.
