cadal questo com'è per un niubbo?
Lama 2 the Indoor-Helicopter for everybody!
The new Lama 2 with modern coaxial rotorsystem was developed by professional engineers to provide you an easy controllable stabile flight-characteristic. Due to its easy handling this is the perfect model for beginners! After you get used to the helis handling after a short time, youll enjoy unlimited flight-fun! The helicopter is equipped with a stabilizer-rod, which provides a best possible flight-control! The LiPo-battery can be perfectly charged with the included LiPo-Balancer to increase the batterys lifetime!
Box contents:
- Lama 2 helicopter
- Built-in receiver and servos
- 4 channel transmitter
- 7,4 V 800 mAh Lithium-Polymer-battery
- Battery-balancer
- 220 / 12 V charger
- 4 x spare-rotor-blades
Technical data:
Main-Rotor: approx. 340 mm
Length: approx. 360 mm
Weight: approx. 250 g (without Accu)
RC: 4 channel
Accu: LiPo 7,4 V/800 mAh
Motor: 180er 2x
Construction time: 100 % ready to fly
Flight time: approx. 12-15 min
