Originalmente inviato da Silvagni A me hanno riferito che se monto un 2w che ha l'albero da 3.17 devo spessoralo con un tondino di ottone per portarlo a 4mm |
Fidati, ti hanno riferito male.......
The perfect fit for medium sized Jets, The WeMoTec Minifan is the fan of choice for some of todays
Hottest Jets. This unit comes standard with a 3.17mm (1/8") motor adaptor, for the 29mm and 400-480 sized motor's.
Properly equiped, the 68mm sized Minifan can be spun to over 50,000 + rpm, producing in excess of 10 Newtons of thrust.
Mega Brushless Motors are ideally suited to power the Minifan, the
16/15/2 and
16/15/3 motors just bolt right in, and they can spin the Minifan up to 55,000 rpm @ 500 Watts of power. You cannot buy a better fan for the money, period.
