Eeco La Risposta Di Npm!!!
HO RIPORTATO IL PROBLEMA DIRETTAMENTE ALLA NPM E GENTILISSIMI MI HANNO RISPOSTO. COSA NE PENSATE?
"Hello,
happy that you get the Fury.
there is no mistake on the model. Benoit is great specialist. Some people who look on incidence, think also there was a mistake before flying. all is laser cut, we can't do mistake at building on the different parts.
In 3D we use a cg very far away from leading eadge to be easy to do manouvers at vertical; If you want to use your model more in aerobatic conditions, you have to use cg more close than leading edge. It depands you need.
If you are not Ok with 3D flight, ask to a friend to do the first flight.
Benoit and Christophe don't follow the ideas of everybody it's because they are innovative, they test all. We work with them since a very long time and test the models and perfect them months before production and even after we try to perfect again to have the highest and best flights.
Fly with him and don't only follow "the theory".
Best regards
NPM"
