Vecchio 07 giugno 07, 15:04   #142 (permalink)  Top
ireen
Data registr.: 15-02-2007
Aiuto
Questo è il regolatore ed il motore con relative caratteristiche . Cerco le spiegazioni per programmare il regolatore.
Specifications:
RC Smart 30A Speed Controller
-Size: 62mm x 26mm x 8mm
-Weight: 33g each
-Constant Current: 30A
-Max Current: 40A
-Input Volt: 3V - 12V
-Low-Voltage Cutoff: Auto detect and set
Advantage of the RC Smart Speed Controller
-Low resistence
-High rate PWM
-Sixteen cells Max (with BEC disabled)
-User programmable brake
-Low voltage auto setting based on battery
-Throttle range self-adjusting
-Soft start ramp up
-Runs motor in forward or reverse
-Auto motor cutoff with reset
-Safe power arming program ensures motor will not run accidentally after turn on
-Low torque start
-Auto shut down when signal is lost
RC Smart Evo. 4200 Outrunner Brushless Motor
-Rpm(Kv): 4200Rpm/V
-Max Currect: 25A
-Max Eff: 98%
-Max Watt: 200W / 11.1v
-Weight: 36g (Motor only)
-Total Length: 49.3mm (Motor only)
-Motor Body Diameter: 25.9mm
-Shaft Diameter: 2.97mm(Front)
-Shaft Length: 22.5mm
-Recommended Input Voltage: 6 - 18 Volt
sono alle prime esperienze con il fai da te ....super bandit!-regolatore.jpg
ireen non è collegato   Rispondi citando
