trovato...
The tiniest 3D capable helicopter.
Mainframe and fiber stiffener plate result in a strong, rigid but lightweight frame.
Equipped with collective pitch mechanism (variable pitch).
Fully equipped ball bearings.(16 micro bearings)
2-bearing tail pitch sliderproduces precision tail control.
Easy replacement of stabilizer and adaptor is suitable for beginners and intermediate pilots.
Seesaw head with bell-hiller system.
Loaded with a 180-class brushed motor with enough power for acro flight.
ECCPM collective pitch mechanism (variable pitch).
Only a short time needed for completion. (95% factory assembled)
Belt driven tail rotor.
Extensive upgrade parts and option parts available.
Specification:
Overall length: 345mm (including cabin & canopy)
Main rotor diameter: 340mm
Tail rotor diameter: 100mm
Motor: 180-class brushed motor (KV4800 brushless motor for option)
Flying weight: 180g (It may vary according to size of a battery pack and R/C gears.)
Main rotor blades: plastic coated formed blades (2 different types included)
Flying duration:
6 ~ 8 minutes with 7.4v/550mah Li-Po battery
10~12 minutes with 7.4v/800mah Li-Po battery
molto carino...
