Vecchio 14 marzo 24, 00:18   #7264 (permalink)  Top
m.rik
L'avatar di m.rik
Data registr.: 28-06-2005
Residenza: Milano
Arrow New Firmware & Windows, Android, iOS APP’s 3.4.158 release:
As usual new Firmware notifications will be automatic, and system will prompt user of the presence of new updates once powered unit is connected to a Windows PC or Android devices or iOS devices with Internet connection active.
For those with Brain2/iKon2 that do not frequently use the APP/Software (because the flight controller unit is fine as it was set up), let's take a look at what is coming with this update (for free) in addition to previous versions already released:
- Software: 3.4.158, Firmware: 3.4.158 (65° official release), 13 March 2024:
• Improved compatibility of integration when F.Bus protocol is used with some receivers.
• In order to further reduce the Tail Kick phenomenon with Hobbywing ESCs, the duration of the very first part of the governor ramp-up was doubled (in addition to programming Hobbywing ESCs by disabling the “FreeWhell”, minimizing the "Startup Power" and keeping the "DeadBand" parameter of the governor of the flight controller below 10)
• Automatic Channel Assignment has been improved when the multiprotocol icon is selected as explained in the instructions in panel 3 of the wizard, even when Spektrum DSMX satellites connected to the SAT1 and/or SAT2 connectors receive the signal correctly, but the receiver connected to the CH3 connector still does not receive the signal (not binded or not powered or wired incorrectly)
• Added “Abs Altitude m” to the loggable parameters (other than “Rel Altitude m”)
• Added to the ETHOS, EdgeTX, OpenTX telemetry the new precision current for BEC (BEC current is measured only by Kontronik Kosmik & Kolibri, YGE HVT)
• Swashplate H4: eliminated at power on possible micromovements that cause strains on swashplate uniball with some types of servos performing an initialization procedure
• With CheckMode active, the ability to activate Rescue is disabled
• Prevent possible repetitions of the Rescue procedure already performed via B-Aux1 radio channel by activating Rescue also on one of the Setups and vice versa prevent repetitions of the Rescue already performed via one of the Setups by activating Rescue also via B-Aux1 radio channel
• Added: Oxy 4 MAX, Oxy 5, Oxy Flash, TRON Electric, NITRON Nitro, KST SV3312-12 HV, KST DS515MG, KST X15-755X, KST X15-855X, TORQ CL0508 HV, TORQ CL0604T HV, TORQ BLS0705M, TORQ BLS0808, GDW BLS 892 MG, GDW BLS 895 MG, Spektrum SPMSH6060, Azure & MS-Composit blades, Jumper Transmitter on the curtain of first page of the Wizard and in Servo chart
• Added “Auto Level Disactivated” & “Rescue Expired” events
• Added and improved some functions used to be able to provide a better remote assistance
• Released first version of Fast Forward Integration for EdgeTX/OpenTX (inside “Brain2OpenTX-EdgeTX.zip file)
• Released new version of Spektrum Integration
• Released new version of ETHOS Integration (see ReleaseNotes.txt)
• Released new version of EdgeTX/OpenTX Integration (see ReleaseNotes.txt)
• Released new version of TBS/ELRS Integration (see ReleaseNotes.txt)
• Released new version of Jeti Integration (see ReleaseNotes.txt)
• Released new version of Graupner Integration
• Added some diagnostic info in Events files
• The order of the list of parameters controllable via dials has been aligned with the new ordering of the ADVANCED section and Integrations
• Added some instructions, changed some instructions, some tooltip, some labels in the app and also in the Integrations to be clearer
• Revised French instructions
• Revised German instructions
• New version of the document “README_for_Analogic_integration_by_TX_dials.pdf ” document
• New version of the document “README_for_ESC_datas_log_and_telemetry.pdf”
• New version of the document “README_for_Spektrum_Integration.pdf”
• New version of the document “README_for_OpenTX_EdgeTX_integration_for_BRAIN. pdf”
• Improvements / optimization / compression / size reduction / code speedup
www.msh-electronics.com
m.rik non è collegato   Rispondi citando
