New Firmware & Windows, Android, iOS APP’s 3.4.149 release:
As usual new Firmware notifications will be automatic, and system will prompt user of the presence of new updates once powered unit is connected to a Windows PC or Android devices or iOS devices with Internet connection active.
For those with Brain2/iKon2 that do not frequently use the APP/Software (because the flight controller unit is fine as it was set up), let's take a look at what is coming with this update (for free) in addition to previous versions already released:
- Software: 3.4.149, Firmware: 3.4.149 (64° official release), 30 November 2023:
• Added to the Micro Brain2 FCU the management of the B-Aux3 channel on the CH4 connector to be able to control buzzer activation, retractable landing gear, lights, winch, smoke, etc. etc. via PWM signal
• Added handling of the new SKY telemetry parameter introduced by Spektrum with the November 21 AirWare update
• Introduced minor changes in the parameters of the "BEGINNER" flight style so that it can also be used satisfactorily in scale models, and added some information about scale models in the instructions
• Until panels 1 through 6 of the Wizard are completed, the servo outputs remain off so that panels prior to 7 and especially panel 5 can be configured correctly without being affected by servo movements
• In model with tail motor, to facilitate the tail setup minimum, zero and maximum, now when check mode is active (EG in panel 9 of the Wizard) tail motor can run also if main throttle is at zero
• Improved in software matching of the actual manageable and working functions of the old Brain and Micro Brain flight controllers
• Added “Cancel” to the “change language” confirmation message
• Added and improved some functions used to be able to provide a better remote assistance
• Changed some instructions, some tooltip, some labels in the app and also in the Integrations to be clearer
• Revised French instructions
• New version of the document “README_for_ESC_datas_log_and_telemetry.pdf” (+ELRS)
• New version of the document “README_for_OpenTX_EdgeTX_integration_for_BRAIN. pdf” (+TBS)
• New version of the document “README_for_Spektrum_Integration.pdf” document
• Improvements / optimization / compression / size reduction / code speedup
Android / iOS app’s:
All new features and improvements already listed for this "Software & "Firmware” release
As usual, the release of Android and especially iOS apps publication still needs some time for testing and approval by Google & Apple
Enjoy!
