Vecchio 16 ottobre 23, 22:36   #7248 (permalink)  Top
m.rik
L'avatar di m.rik
Data registr.: 28-06-2005
Residenza: Milano
New Firmware & Windows, Android, iOS APP’s 3.4.139 release:
As usual new Firmware notifications will be automatic, and system will prompt user of the presence of new updates once powered unit is connected to a Windows PC or Android devices or iOS devices with Internet connection active.
For those with Brain2/iKon2 that do not frequently use the APP/Software (because the flight controller unit is fine as it was set up), let's take a look at what is coming with this update (for free) in addition to previous versions already released:
- Software: 3.4.139, Firmware: 3.4.139 (63° official release), 16 October 2023:
• Added the telemetry decodify of OMP ESC
• Implemented Forward Programming Integration for those who have Spektrum telemetry receivers on their models but have switched to using transmitters with OpenTX / EdgeTX operating systems and Multi Module Radio frequency. An LUA app will be released later
• Corrected the calculation of vibration frequencies with some production batches
• Added in apps and integrations to the list of adjustable parameters via Dials "TAIL: Proportional Gain" to simplify life to users who have set tail gain to "Is set in software."
• Modified the window for Bluetooth Configuration so that it can also contain longer texts (French)
• Changed some labels in the app and also in the Integrations to be clearer (EG: “VSpeed” to “Vertical Speed”)
• Lowered the automatic RPM drop when mAh Max Usage is exceeded from -18,75% to -12,5% for low main rotor speed flyer
• When mAh Max Usage is set at maximum (7000mAh) the function is totally disabled
• Raised the “Min V to Go” threshold from 3.82V to 3.88V
• Added in page 1 of the Wizard the “Radix” brand in the “Main Blades” and “Tail Blades” lists
• Added in page 1 of the Wizard the “AGF B53BHP-V2” servo in the “Cyclic Servo” list
• Added in page 1 of the Wizard the “HiTec HSG-8315BH” servo in the “Tail Servo” list
• Added in page 1 of the Wizard the “FullPower” brand in the “Power Supply Type” list
• Added in page 1 of the Wizard the “FlySky” brand in the “Transmitter Brand” list
• Made visible and operable in the telemetry selection dropdown the "DISABLED" item that was already displayed with the old flight controllers now also with the new flight controllers
• Although the confirmation prompt "Are you sure Y/N" is present, some users still reset by accident. For this reason, moved to the bottom of the command list in the File menu the command "Reset to factory defaults ..."
• More diagnostic information saved in the configuration files
• Used and updated version of the Compiler
• Changed some instructions, some tooltip, some labels in the app and also in the Integrations to be clearer
• Revised French instructions
• New version of the document “README_for_OpenTX_EdgeTX_integration_for_BRAIN. pdf” (+TBS)
• New version of the document “README_for_ESC_datas_log_and_telemetry.pdf” (+ELRS)
• New version of the document “README_for_Spektrum_Integration.pdf” document
• Improvements / optimization / compression / size reduction / code speedup
Android / iOS app’s:
All new features and improvements already listed for this "Software & "Firmware” release
Revised Firmware Update procedures to make them more stable on some devices that were experiencing problems
As usual, the release of Android and especially iOS apps publication still needs some time for testing and approval by Google & Apple
Enjoy!
www.msh-electronics.com
m.rik non è collegato   Rispondi citando
