| New Firmware & Windows, Android, iOS APP’s 3.4.094 release:
As usual new Firmware notifications will be automatic, and system will prompt user of the presence of new updates once powered unit is connected to a Windows PC or Android devices or iOS devices with Internet connection active.
For those with Brain2/iKon2 that do not frequently use the APP/Software (because the flight controller unit is fine as it was set up), let's take a look at what is coming with this update:
- Software: 3.4.094, Firmware; 3.4.094 (55°), 14 December 2022:
• Improvements, changes, and corrections to previous versions when ESC telemetry is active with F.Bus protocol
• A new LUA app for Ethos version that now works also with F.Port protocol and S.Port+S.Bus protocol, and also display on top bar which is the Setup (1/2/3) active whose values are shown and added in the list of diagnostic parameters selectable in page 11 (Diagnostic) also "Rel.Altitude" and "VSpeed"
• Added decoding of a Futaba SBS-01A sensor connected to the S.Bus2 line to be able to log "Altitude" & "VSpeed" parameters in the Flight Log memory
• Added decoding of a Robbe “Vario Sensor” connected to the S.Bus2 line to be able to log "Altitude" & "VSpeed" parameters in the Flight Log memory
• Added decoding of a Graupner “GPS” sensor connected to the telemetry line on CH3 to be able to log "Altitude" & "VSpeed" parameters in the Flight Log memory
• Added decoding of a FrSky “VARIOMETER SENSOR” sensor connected to the telemetry Smart.Port on CH3 to be able to log "Altitude" & "VSpeed" parameters in the Flight Log memory
• Added the possibility of connecting a Jeti “Mvario2” sensor to SAT2 connector and decode the signal to be able to log "Altitude" & "VSpeed" parameters in the Flight Log memory (also for non-telemetric receivers / protocols)
• Added the possibility of connecting a Jeti “MALTI EX” sensor to SAT2 connector and decode the signal to be able to log "Altitude" & "VSpeed" parameters in the Flight Log memory (also for non-telemetric receivers / protocols)
• Added in the “Telemetry Input” subpanel a new “Vario” checkbox
• Now with Windows app, using the left Ctrl key of the keyboard it is possible to update the Events windows, start/stop real time logs, start/stop real time vibrations
• Added some new functions for diagnostic purpose loading an user mtr configuration file (Servo Voltage, CPU temperature, etc)
• Revised French instructions
• New “README_for_Ethos_Integration_for_BRAIN.pdf” document
• New version of “README_for_ESC_datas_log_and_telemetry.pdf” document with a new page for variometers
• Improvements/optimization/compression/size reduction/speed up of the code
Android / iOS app’s:
All the new functions and improvements already listed for this "Software & "Firmware” release
As usual for the Android and especially iOS app publication is needed some more time
Enjoy!
