Vecchio 14 giugno 20, 12:02   #6 (permalink)  Top
davinja
L'avatar di davinja
Data registr.: 25-09-2012
Residenza: Vicenza
https://www.graysonhobbyshop.com/jum...mper-t18-lite/
La T18 Pro ha i sensori Hall ALPS RDC90 prodotti in Giappone, usati anche da Futaba nella T18MZ, segue descrizione:
The Jumper T18 pro will use the Japanese made ALPS RDC90 gimbals. These same gimbals can be found on the Futaba T18MZ. If you have not had a chance to use the ALPS RDC90 gimals, they are EXTREMELY smooth to the touch. If you are an expert pilot then you will definitely enjoy the silky response from the ALPS RDC90 gimbals, however, if you are still hitting every tree in the dessert , then you probably may just want to look at the Jumper T18
Ultima modifica di davinja : 14 giugno 20 alle ore 12:06
davinja non è collegato   Rispondi citando
