Ho cercato i squadrettare il segnale, dividendolo in sezioni di valore definiti.
questo e' il massimo che ottengo, ma non cambia molto provalo te.
hai due scale una per sterzo e una per gas.
piu' piccolo e' il valore maggiore e' la precisione 1-n.
Codice:
#define Neutral 1500 // -- minimum forward signal
#define Maxspeed 2000 // -- maximum forward signal
#define Antsx 1000 // -- in front servo signal sx
#define Antdx 2000 // -- in front servo signal dx
#define Postsx 1000 // out rear servo sx endpoint if inverted with postdx it reverse
#define Postdx 2000 //-- out rear servo dx endpoint if inverted with postsx it reverse
#define Center 0 //-- add or subtract xx value to center steering
#define Tolerance 3 //-- if poor quality servo vibrates try 5
#define Max_gain 950 //-- gain steering reduction by throttle if reverse add -
#define Slowlimit 1600 //-- slow forward without endpoint correction
#include <MobaTools.h>
MoToServo myservo;
unsigned int Rxpulse;
unsigned int Gaspulse ;
unsigned int Gain;
signed int NewPos, OldPos;
int Stato;
int Stato_Led=0;
boolean Cmd_Led = false;
int Ledpin=13;
int Led=0;
unsigned int scala_RX=5;
unsigned int scala_GAS=20;
void setup() {
pinMode(7, INPUT); //-- throttle signal in pin
pinMode(8, INPUT); //-- front servo signal in pin
pinMode(Cmd_Led, OUTPUT);
myservo.attach(10); //-- rear servo signal out pin
myservo.setSpeed(128);
Stato = 0;
void loop() {
if (Stato == 0) {
//lettura
Rxpulse = pulseIn(8, HIGH);
//Rxpulse = (((Rxpulse-Antsx)/scala)*((Antdx-Antsx)/scala))+Antsx;
Rxpulse = Rxpulse - Antsx;
Rxpulse = Rxpulse / scala_RX;
Rxpulse = Rxpulse * scala_RX ;
Rxpulse = Rxpulse + Antsx;
Gaspulse = pulseIn(7, HIGH);
Gaspulse = Gaspulse - Neutral;
Gaspulse = Gaspulse / scala_GAS;
Gaspulse = Gaspulse * scala_GAS;
Gaspulse = Gaspulse + Neutral;
if (Stato == 1) {
//Calcolo
if (Gaspulse > Slowlimit) {
Gain = map(Gaspulse, Slowlimit, Maxspeed, 0, Max_gain );
NewPos = map(Rxpulse, Antsx, Antdx, (Postsx + Gain), (Postdx - Gain));
Led=1;
else {
NewPos = map(Rxpulse, Antsx, Antdx, Postsx, Postdx);
Led=2;
if (Stato == 2) {
//scrittura
if (abs(NewPos - OldPos) > Tolerance) {
myservo.write(NewPos + Center);
OldPos=NewPos;
// Incrementa stato per il prossimo loop
++Stato;
// Incrementa tempo led per il prossimo loop
++Stato_Led;
if (Stato == 3) {
// riparte da 0
Stato = 0;
//ritardo esecuzione cicli/stati
delay(1);
if (Led == 1) {
//led veloce
if (Stato_Led>20) {
Cmd_Led= !Cmd_Led;
Stato_Led=0;
digitalWrite(Ledpin, Cmd_Led);
if (Led == 2) {
//led lento
if (Stato_Led>60) {
Cmd_Led= !Cmd_Led;
Stato_Led=0;
