Vecchio 17 dicembre 19, 09:06   #111 (permalink)  Top
manfredviii
L'avatar di manfredviii
Data registr.: 18-07-2007
Residenza: Condino
Originalmente inviato da rosnik Visualizza messaggio
Dimenticavo...
The firmware ha il tuo modulo interno o esterno?
Deve esser superiore o uguale a v.1.2.1.85 altrimenti và aggiornato con USB-to-serial adapetr.
Considerate che JumperTX è morto,
e quindi passare a OpenTX è indispensabile comunque.
A tal proposito è uscito un comunicato JumperXYz:
Recently, many T16 owners are asking for how to update their radio from JumperTX into openTX.
Firstly, we'd like to take this opportunity to express our gratitude to openTX team and Pascal Langer. Many thanks for your great job!
And to update your T16 from JumperTX into openTX:
1) Please check the version of your JP4IN1 module at the page of T16 model set up. Any module that is under version V1.2.1.85 will need to update it into the version V1.2.1.85 or above.
2) If your module version is V1.2.1.85 or above, you can update the radio firmware directly. Here is a video of showing how to do it: https://www.youtube.com/watch?v=BXhLk_l6280&t=281s (Many thanks TMac for the wonderful video)
How to update the module firmware:
1) If you are still using external JP4IN1, you can connect the module with USB to PC and update the firmware.
2) If you are having internal JP4IN1, and the version is under V1.2.1.85, you'll need a USB-to-serial adapter.
3) Here is a video of showing how to do it: https://www.youtube.com/watch?v=Dex92d7IQWI&t=44s (Many thanks TMac for the wonderful video)
USB-to-serial adapter, if you can't find the adapter in a local shop:
1) Jumper will offer the adapter free of charge. And you'll be in charge of the shipping cost.
2) You'll able to find the adapter on Jumper Aliexpress store. We'll share the link of the adapter on Facebook once it is available. Estimate in 2 - 3 weeks.
3) We'll need photos of your T16 S/N# and the screenshot of the module version before sending the adapter.
Here you can download the radio firmware: https://www.jumper.xyz/portal.php?mod=view&aid=17
Or you can download it from openTX website.
Last but not least, the firmware update is not needed if the radio is working all good. Only proceed if you know what you are doing. Updating firmware incorrectly may void the warranty.
grazie mille dell'assistenza.
Stasera provo
manfredviii non è collegato   Rispondi citando
