da un indagine del dopo gara in Olanda questi sono i gruppi propulsori che hanno usato:
I used a 2580kV Sunnysky motor from AliExpress. With a Vladimir 25 mm spinner with 7x4 prop. On 3S 450Ah easy to start at 70 m within 7 sec.
We currently use the F30 with 2300kV and our special Spinner from Vladimir using a 6*3prop. You can use it on 2S, 3S and even 4S. Very cool setup. But the motor is tough to find. So we are looking for alternatives...
I am using a Cobra E36 edition, which I like a lot. It is very light and still very strong. Only available in the USA
Snipe 2e Power Set
Flavio
