Cylinder Capacity 4.59 cu.in 75.4 ccm
Power Rating 7.5 HP 5.48 kW
Bore Diameter 1.929 in 49 mm
Stroke 1.57 in 40 mm
Weight 5.25 lbs 2390 g
Speed Range 8500 RPM
Crankshaft 3 Ball bearings
Connecting Rod Needle bearings on both ends
Oil / Gasoline Ratio 1:50 - 1:80 Mix
Ignition Input Voltage: 6.0 to 8.0 V
6.0 V NiCD / NiMH or 7.2 V LiPo / Li Ion
Propeller 2-Bladed
22 x 12
24 x 8
24 x 10 3-Bladed
19 x 12
20 x 14
