Ho ritrovato l'articolo che parlava del radiocomando:
https://www.rcgroups.com/forums/show...-Review-thread
dicono:
Stick feel is adequate for the quads and the V911, but I think that pairing this particular transmitter with the 4 channel Power Star aircraft is an honestly bad decision. The stick tension is very high and overall, it’s very hard to fly the Power Star 2/X2 in a controlled manner with this particular transmitter. My opinions of the helis would have been very different had I not tried out the Power Star 2/X2 with the transmitter that comes with the Power Star 1/X1. This aircraft uses a new proprietary protocol that is NOT compatible with any previous WLToys aircraft INCLUDING the V911/V922-955/V9X9/V2X2. It also does not bind to any transmitter on the market today other than its own protocol.
e poi:
With the stock transmitter, I found it very hard to control the aircraft in any kind of precise manner. I would say that flying the Power Star X2 with this particular transmitter is dangerous for beginners..
After a few minutes of fiddling with the stock transmitter (which doesn’t give you the ability to switch between 3 axis and accelerometer modes, by the way), I gave up and went back to the transmitter that was bundled with my Power Star 1.
I’ll say that the Power Star 2 and the X2 are completely different animals when flown with the larger transmitter.
Quindi se ho capito bene raccomandano di usare il radiocomando del Powerstar 1 che è quello che ho messo nel likn sopra , è giusto?
