anzi, leggete qui: Set the rudder stick to the neutral position, switch the transmitter sensitivity
switch between the AVCS and normal modes at least 3 times at an interval of 1 second or less, then set the switch to the AVCS position.
This operation memorizes the AVCS side neutral data to the gyro. At
this time, the monitor LED flashes once. The neutral data is also
memorized by setting the transmitter sensitivity switch to the AVCS
position and turning on the gyro power again. |
