Chi usa l'applicazione Windows ne è ormai già automaticamente venuto a conoscenza.
Per chi invece con il Brain non usa più così frequentemente l'applicazione Windows perché la centralina va ormai bene come è stata settata, informo chi ne fosse interessato che questa settimana è stato rilasciato il seguente aggiornamento firmware/Software con importanti novità, aggiunte e miglioramenti.
Soprattutto per chi usa sistemi radio Spektrum:
- 3.1.010 (firmware 3.1.010) 01 August 2017
- Doubled the maximum amplitude values of acceptable vibrations on X, Y, Z axis beyond which Auto Level and Rescue become unreliable, so now max vibrations can be double than before
Added Spektrum "Integration"
Now with Spectrum SRLX protocol selected, is possible to connect also one or two DSMX sats on SAT1 and SAT2 connectors for improve the redundancy and security on large models.
- Added in the MANUALS section the "README_for_Spektrum_Integration.pdf" document
Added in Graupner integration the possibility to setup telemetric alarms values that now warn user with voice, sound and red text on screen.
Masked an Hobbywing ESC issue that send ghost current value if throttle is fast cut. Now if the ESC values of Power Out and RPM are either zero, the ghost current sent by ESC is masked to zero
- Improved the save routine of modified parameters with additional error checks.
- Further improvements on S.Bus and S.Bus2 signal reception and telemetric transmissions
- Further improvements on Spektrum SRXL signal reception and telemetric transmissions
- Increased the acceptable ghost RPM sent by Castle Creation when unpowered from 150rpm to 170rpm
- Added a new progress bar that during Firmware update display the erasing progress of the older firmware
Diagnostics -> Events new improved communication protocol with the Brain
Diagnostics -> Events enabled in demo mode
Diagnostics -> Vibrations new improved communication protocol with the Brain
Diagnostics -> Vibrations enabled in demo mode
- Added in wizard step 1 under the list of motor the KDE brand
- Added in wizard step 1 under the list of batteries the Turnigy brand
- Now in basic step 1 selecting from factory default the model, the size of the blades is changed
- In basic step 1 for the OXY 200 model changed the type of swashplate selected from factory default
- Added in basic step 1 Henseleit TDR 700 Electric, Minicopter Diabolo 550 Electric, Minicopter Diabolo 600 Electric, Minicopter Diabolo 700 Electric, Minicopter Diabolo 800 Electric, Align T-Rex 450L Electric
- Added in Servos chart and servo list Futaba servos BLS272sv for cyclic and BLS276sv for tail
- Improved version of "README_for_ESC_datas_log_and_telemetry.pdf"
- Updated in the MANUALS page the "README_for_HOTT_telemetry_and_integration_for _BRA IN.pdf" with some setup for alarms infos
- Removed the debugging labels in Governor (
https://www.helifreak.com/showpost.php
- Added in the firmware update tree window the serial number of the connected Brain
- Changed in the Wizard page 12 and in the Advanced Governor the label "Current Speed xxxx rpm" to "Current Main Rotor xxxx rpm"
- Changed in software each "Fast Gyro Servo" occurrences to "Fast Tail Servo"
- Improved Russian resources
- Minor instructions improvements
- Improvements/optimization/compression/reduction/speed up of the code
