Originalmente inviato da maverick4you Da poco passato al mondo dei motori a scoppio, benzina, avevo finora acquistato modelli con motori gia rodati (bene o male dai precedenti proprietari)
Adesso sto allestendo un modello e ho acquistato il motore in oggetto, al di la delle caratteristiche, buono non buono potente o meno, vorrei un consiglio sulla miscela da preparare per la prima accensione-rodaggio.
il sito del costruttore indica: " Engine Break In
Break in running should be done with regular 90 octane gas mixed with a high quality petroleum based 2 cycle oil at a ratio of 30:1. The engine should be run installed in the airframe with wings attached, on the ground for at leat 20 minutes at 2500rpm. Ground running should be done with a slightly smaller prop and with the cowl off to promote good cooling. It is not recommended that you run the engine in a test stand, as they do not allow vibration energy to be properly dissipated. Plus, it is not needed. Your engine is ready to go.
During the break-in process (a couple of gallons of gas) the carburetor may need to be adjusted and the engine should be flown at light load and varying speed for enough time to have the oil/gas run through it.
After you have run a couple of gallons of fuel through, you can switch to a full synthetic 2 cycle oil mixed at a ratio of 50:1. Note that when you switch to synthetic 2-cycle oil, it is likely that the carburetor mixture and idle speed will need to be adjusted.
We recommend high quality synthetic 2 cycle oil. Never use outboard motor 2 cycle oil".
io interpreto come una miscela al 3% di olio per il rodaggio e a 2% una volta completato.
Consigli?
Grazie, ciao. |
RCGF 15 ? quale per esattezza?
perche il 15 della rcgf è la versione BM...
o intendi RCG di hobbyking?
