| User
Data registr.: 19-01-2005 Residenza: 33170 e dintorni
Originalmente inviato da aero330 Tenendo presente tutto quello che fin'ora è stato detto (dovrei aver messo tutto): Codice: #define sclk 13
#define mosi 11
#define cs 10
#define dc 9
#define rst 8 // reset
#include <Adafruit_GFX.h> // Core graphics library
#include <Adafruit_ST7735.h> // Hardware-specific library
#include <SPI.h>
Adafruit_ST7735 tft = Adafruit_ST7735(cs, dc, rst);
// number of analog samples to take per reading, per channel
#define NSAMP 128 // number of samples to take befor displaying (128=2^7)
// voltage divider calibration values
#define Dv1 11.00
#define Dv2 11.00
//number of channels
#define N_CH 2
// ADC reference voltage / calibration value
#define VREF 5.00
unsigned int u16_sum[2] = {0, 0}; // u16_sums of samples taken
unsigned char u8_Scount = 0; // current sample number
float f32_AVvolts[2] = {0.0, 0.0}; // calculated voltages
char u8_cnt1 = 0; // used in 'for' loops
float f32_V_max[2] = {0.00 ,0.00};
float f32_V_min[2] = {100.00, 100.00};
void setup()
tft.initR(INITR_BLACKTAB); // initialize a ST7735S chip, black tab
tft.fillScreen(ST7735_BLACK); // clear screen
tft.setTextColor(ST7735_WHITE);
tft.drawRoundRect(2, 10, 120, 110, 5,ST7735_WHITE);
tft.setTextSize(1);
tft.setCursor(5,0);
tft.println("2 channel voltmeter");
tft.setTextColor(0XFF00);
tft.setCursor(0,140);
tft.println(" Caution max voltage 55vdc");
void loop()
ADC_Reading(); //Read voltages
MaxMin_Detection(); //Detect MAX/MIN and mean
Print_V1(); //Display V1 and V2 voltages
Print_V2();
tft.drawRoundRect(2, 10, 120, 120, 5,ST7735_WHITE); // draw a rectangle
Reset_var(); //Reset variables
void ADC_Reading(){
while (u8_Scount < NSAMP) {
// sample each channel A0 to A1
for (u8_cnt1 = 0; u8_cnt1 < N_CH; u8_cnt1++) {
u16_sum[u8_cnt1] += analogRead(A0 + u8_cnt1);
u8_Scount++;
delay(10);
void MaxMin_Detection(){
// calculate the voltage for each channel
f32_AVvolts[u8_cnt1] = ((u16_sum[u8_cnt1]>>7) * VREF) / 1024.0;
if(f32_AVvolts[u8_cnt1] > f32_V_max[u8_cnt1]){ //get MAX value of sample
f32_V_max[u8_cnt1] = f32_AVvolts[u8_cnt1];
if(f32_AVvolts[u8_cnt1] < f32_V_min[u8_cnt1]){ //get MIN value of sample
f32_V_min[u8_cnt1] = f32_AVvolts[u8_cnt1];
void Print_V1(){
// voltage 1 - V1(pin A0)
tft.setTextColor(ST7735_YELLOW,ST7735_BLACK); // set color for V1
tft.setTextSize(3);
tft.setCursor(15, 20);
tft.print("V1 ");
tft.print(f32_AVvolts[0] * Dv1, 1);
tft.print("V ");
// voltage 1 - mean of V1
tft.setTextColor(ST7735_GREEN,ST7735_BLACK);// set color for V1
tft.setTextSize(2);
tft.setCursor(15, 46);
tft.print("Vmax ");
tft.print(f32_V_max[1] * Dv1, 1);
tft.print("V ");
tft.setCursor(15, 63);
tft.print("Vmin ");
tft.print(f32_V_min[1] * Dv1, 1);
tft.print("V ");
void Print_V2(){
// voltge 2 - V2 (pin A1)
tft.setTextColor(ST7735_CYAN,ST7735_BLACK);// set color for V3
tft.setTextSize(3);
tft.setCursor(15, 80);
tft.print("V2 ");
tft.print(f32_AVvolts[2] * Dv2, 1);
tft.print("V ");
// voltage 2 - mean of V2
tft.setTextColor(ST7735_WHITE,ST7735_BLACK);// set color for V4
tft.setTextSize(2);
tft.setCursor(15, 106);
tft.print("Vmax ");
tft.print(f32_V_max[2] * Dv2, 1);
tft.print("V ");
tft.setCursor(15, 123);
tft.print("Vmin ");
tft.print(f32_V_min[2] * Dv2, 1);
tft.print("V ");
void Reset_var(){
// reset variables
u8_Scount = 0;
u16_sum[u8_cnt1] = 0;
} Sul display dovresti vedere una cosa del genere: 2 channels voltmeter
/--------------------------------------------\ V1 0.00 V Vmax 0.00V Vmin 0.00V V2 0.00 V Vmax 0.00V Vmin 0.00V
\--------------------------------------------/ Caution max voltage 55vdc
Se le scritte sono decentrate o non allineate correggi tu in base a quello che vedi su display agendo su tft.setTextSize(), tft.setCursor() e tft.drawRoundRect() | fantastico,domani provo.
nel frattempo ho cercato qualche tutorial per capire meglio sia arduino
che come impostare questo display.
ce ne molto da studiare.
hai qualche consiglio?
sono in debito.
grazie ancora.
Trattiamo bene la terra su cui viviamo: essa non ci è stata donata dai nostri padri, ma ci è stata prestata dai nostri figli
