Allora:
1) collega la scheda arduino al PC
2) apri l'IDE di arduino, vai su "Strumenti ->Scheda" e selezioni quella che utilizzi
e poi "Strumenti -> Programmatore -> AVRISP mkII"
3) scarica i due file ZIP che ti ho messo in allegato
4) vai su "Strumenti -> Sketch -> #includi libreria -> Aggiungi libreria da file .ZIP"
e cerca i due file "Adafruit_GFX.ZIP" e "Adafruit_ST7735".
5) chiudi tutto e riapri l'IDE di arduino
6) "File -> Nuovo", cancelli tutto e incolli questo:
Codice:
#define sclk 13
#define mosi 11
#define cs 10
#define dc 9
#define rst 8 // reset
#include <Adafruit_GFX.h> // Core graphics library
#include <Adafruit_ST7735.h> // Hardware-specific library
#include <SPI.h>
Adafruit_ST7735 tft = Adafruit_ST7735(cs, dc, rst);
// number of analog samples to take per reading, per channel
#define NSAMP 100 // number of samples to take befor displaying
// voltage divider calibration values
#define Dv1 11.00
#define Dv2 11.001
#define Dv3 11.00
#define Dv4 10.985
// ADC reference voltage / calibration value
#define VREF 5.00
int sum[4] = {0}; // sums of samples taken
unsigned char Scount = 0; // current sample number
float AVvolts[4] = {0.0}; // calculated voltages
char cnt1 = 0; // used in 'for' loops
float V_max[4] = {0.00 ,0.00, 0.00, 0.00};
float V_min[4] = {100.00, 100.00, 100.00, 100.00};
void setup()
tft.initR(INITR_BLACKTAB); // initialize a ST7735S chip, black tab
tft.fillScreen(ST7735_BLACK); // clear screen
tft.setTextColor(ST7735_WHITE);
tft.drawRoundRect(2, 20, 120, 110, 5,ST7735_WHITE);
tft.setTextSize(1);
tft.setCursor(5,0);
tft.println("4 channel voltmeter");
tft.setTextColor(0XFF00);
tft.setCursor(0,140);
tft.println(" Caution max voltage 55vdc");
void loop()
// take a number of analog samples and add them up
while (Scount < NSAMP) {
// sample each channel A0 to A3
for (cnt1 = 0; cnt1 < 4; cnt1++) {
sum[cnt1] += analogRead(A0 + cnt1);
Scount++;
delay(10);
// calculate the voltage for each channel
AVvolts[cnt1] = ((float)sum[cnt1] / (float)NSAMP * VREF) / 1024.0;
if(AVvolts[cnt1] > V_max[cnt1]){ //get MAX value of sample
V_max[cnt1] = AVvolts[cnt1];
if(AVvolts[cnt1] < V_min[cnt1]){ //get MIN value of sample
V_min[cnt1] = AVvolts[cnt1];
// display voltages on TFT LCC Display
// voltage 1 - V1(pin A0)
tft.setTextColor(ST7735_YELLOW,ST7735_BLACK); // set color for V1
tft.setTextSize(2);
tft.setCursor(15, 40);
tft.print("V1 ");
tft.print(AVvolts[0] * Dv1, 1);
tft.print("V ");
// voltage 2 - V2(pin A1)
tft.setTextColor(ST7735_GREEN,ST7735_BLACK);// set color for V2
tft.setCursor(15, 60);
tft.print("V2 ");
tft.print(AVvolts[1] * Dv2, 1);
tft.print("V ");
// voltge 3 - V3(pin A2)
tft.setTextColor(ST7735_CYAN,ST7735_BLACK);// set color for V3
tft.setCursor(15, 80);
tft.print("V3 ");
tft.print(AVvolts[2] * Dv3, 1);
tft.print("V ");
// voltage 4 - V4(pin A3)
tft.setTextColor(ST7735_WHITE,ST7735_BLACK);// set color for V4
tft.setCursor(15, 100);
tft.print("V4 ");
tft.print(AVvolts[3] * Dv4, 2);
tft.print("V ");
// reset count and sums
Scount = 0;
sum[cnt1] = 0;
} 7)clicca in alto sulla freccia a destra ("carica")
8)se tutto è andato a buon fine non ottieni nessun errore ma solo "caricamento "completato"
9) fatto
Ho preso il codice quello completo con le 4 tensioni lette e aggiunto il calcolo dei valori massimi/minimi per ciascun canale.
L'unica cosa è che non li visualizzi perchè non c'è abbastanza spazio sul display, a meno che tu non mi dica come fare (esempio: visualizzo ogni singolo canale ciclicamente con sotto il max/min relativo, oppure i 4 canali contemporaneamente ma con i valori max/min scrittti a fianco più piccoli ecc ecc)
P.s. non ho il display in questione per cui sto facendo tutto al buio
