Per chi usa ancora batterie Ni-MH & Ni-CD e motori a spazzole offro questo caricabatterie con provamotori della LRP ancora con scatola originale.
SPECIFICATIONS :
Battery Type: Ni-MH & Ni-CD ONLY.
Maximum Charge Current: 10 amps
Input Voltage: 11-15V
Charging Modes: Linear and Flex
Charging Capability: 1-8 cells
Charge Current: 0.1-10A
Trickle Current: 0.0-0.4A
Discharge Current: 0.1-10A
Delta Peak: 5-95 mV
Motor Run In Function: 2.0-7.2V 14A
Discharge Cut-Off Voltage: 0.9-7.2V
Multi-Protection System: 3-way
Peak Capacity System: PCS-3
Matching-Mode: Fully automatic measurement of battery pack
12 Volt Input Connector:
Weight: 21.2oz (600g)
RIBADISCO NON CARICA LIPO-LIFE ECC.
VENDO EURO 20 + ss
GIORGIO DELFINO
CARATE BRIANZA
