Originalmente inviato da panterone Avevo inserito un ? Sul post successivo xk con lo smartphone non mi fa modificare il post. Il designe mi piace di quale sta radio. Ma quanti canali reali gestisce? |
This is the latest powerful radio system from FrSky, the Taranis Q X7. This is a lightweight feature packed reliable system and it comes in black or white color scheme. The radio includes a Haptic Vibration Feedback System which provides an alternative feedback system to the voice and sound alert warnings. This 16 channel radio has smooth ball bearing gimbals and is loaded with six switches and two knobs. It runs on OpenTX and files can be shared with the popular X9D Plus. The MicroSD card slot offers unlimited model memory options , it also has a USB port for upgrades and to connect to a PC for adjusting settings. Both sticks come with spring loaded return to center sticks, this makes changing from mode 1 to mode 2 extremely easy to set through the menu and the stick can quickly be set to a stationary throttle by unscrewing four screws and removing a spring. One of the best features of the Taranis Q X7 is its full telemetry capability, as well as RSSI signal strength feedback. Wheel and center enter button makes navigating the backlit menu easy and precise. Equipped with an audio jack output and trainer port as well. And of course a module bay for use with JR-type modules that can be used with other protocol receivers and with the use of a FrSky XJT module this radio can support up to 32-channels. Other features include Receiver Match, Real-Time Flight Data Logging and Super Low Latency for precision flying. Overall this Radio has the features of more expensive transmitters at an unprecedented value.
Source:
https://www.horusrc.com/en/frrsky-ta...r.html?acc=653
